Old 01-20-2016, 09:32 PM   #1
Johnny U
Default Re: Ford 7.3 Power stroke diesel ???
You can check the glow plugs without pulling the v/covers. You should have no more than 2 ohms resistance on a good glow plug. Also if the motor runs rough until the engine is warm then you might have a few sticky injectors. Also in colder weather you should run 10w30 engine oil. hope this helps some.
Johnny U is offline   Reply With Quote
