Old 01-17-2016, 12:02 PM   #61
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: 79 Mustang project U/SA
The Ford gang throwing out the gauntlet. The 4200lb tow vehicle against the little Fords. This will be fun.
Old 02-01-2016, 08:01 AM   #62
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Well I made some good headway over the last week. Picked up some old school Centerline wheels, a 5 lug disk brake front set up from a 94 GT, ordered upper and lower control arms and Mike Graham is going to sell me BJ's C4 with a low 1st gear and a Mark Yacavone converter.Next weekend will be a busy one. Lot's to do.
Old 02-01-2016, 10:14 AM   #63
SSGT Mustang
Liked 204 Times in 54 Posts
The '94 brakes may not be legal. I thought that the '94 went to a different spindle type, which may cause a problem. I don't know, but you may want to check if making the spindle change is considered cross-breeding parts. It may not matter, since aftermarket brakes are allowed. However, the spindles as I recall are very different from the 79-93 spindles, as are the rotors.
If you do run into problems, I have a set of 5 lug rotors and gt calipers that I would donate to you. You have to pick up the shipping costs. I had the caliper pistons coated by Swain, and solid inserts installed. The rotors have 1/2" long studs and new bearings. They spin pretty well.
They're available to you if you need them.
SSGT Mustang is offline   Reply With Quote
Old 02-01-2016, 11:47 AM   #64
RobbieRacer
They are supposed to be a direct bolt in, but if it turns out that I can’t use them I will just take them back. I was going to get 87-93 spindles and run 5 lug rotors, but thought this set up was better. I’ll have to look into it a little deeper.
Thanks for the offer.
Old 02-01-2016, 01:07 PM   #65
SSGT Mustang
The SN95 spindle and hub system is definitely better than the Fox set up. It should be lighter too.
Old 02-01-2016, 07:25 PM   #66
Mike Graham
Liked 341 Times in 67 Posts
Robbie you have PM about your evil FFFord
Mike Graham is offline   Reply With Quote
Old 02-07-2016, 12:42 PM   #67
RobbieRacer
I'm finally getting some work done. Rear end out, cleaning up the sheet metal. Pulling the front end apart. Nasty greasy mess. Got a great deal on the rims. I cant remember the last time I saw Firestone Drag 500 tires. I like the old school rims.
Name:	0207160901 (800x600).jpg
ID:	32370   Click image for larger version
Name:	0207160902 (800x600).jpg
ID:	32371   Click image for larger version
Name:	0207160902a (800x600).jpg
Name:	0207160903 (800x600).jpg
Old 02-09-2016, 02:17 PM   #68
RobbieRacer
Got word from the D7 tech guy. Good news. You guys are right. I can use that intake and It's ok to use the SN95 brakes. Cool.
Old 02-09-2016, 05:00 PM   #69
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Great to see the project rolling along!
Although I think you should take Saturday off and take a car, any car, over to Wild Horse and have some fun with us.
Dave Muller is offline   Reply With Quote
Old 02-10-2016, 08:11 AM   #70
RobbieRacer
Only thing I got to race is a beat up CCCChevy Suburban and a Mini Cooper LMAO. Think I'll be working on the Mustang.
