Old 04-11-2016, 03:38 PM   #1
Tar Heel
Guest
Posts: n/a
Default Re: Lazy off the line
Not being an expert either I would say the single plane intake is mismatched to the converter and gear. If more gear doesn't help (which I think it will because of the intake you're running) then the converter also needs loosened up.
Scott
Old 04-11-2016, 06:21 PM   #2
Keith 944
Keith 944's Avatar
I have a similar setup. All caltracs. 3700# mopar 340 +.030 street/strip Ati 8" converter, eldebrock heads, Vic single intake, 850 Holley, headers, full exhaust, 10.20/1 compression 391 sure grip rear m/t et streets runs 11.40-11.60 year round. I think your hp is a little low at 350 12's is prob correct for the hp. The slide rule shows mine around 450 hp @ 3700# to run what I do. With that said the best et gain was in the converter. I have run a spool with 430 gears only made about .10 diff in et. 60 foot 1.56-1.59 with 430. 1.58-1.61 with 391 gears I would play with the Jets and timing, picked up a couple tenths there. Just checked with the slide rule 350 hp at 3200 pound should be 11.60s at around 112 now of course that is at sea level your 60' is bad. Timing,jets, converter, gears, my converter flashes to 5800 shift at 6200 finish at 6100
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-11-2016, 10:38 PM   #3
bnsfmachinist
Well thanks guys for chiming in. I knew 3.91's wouldn't be ideal but I also knew 1.90 60' couldn't be right and you guys just confirmed!
So, I'm back at the track this coming weekend. Before I go I'm gonna jet down 2 sizes (Dyno operator said it'd be a good idea as we were still a bit rich when we unhooked the car, I just didn't do it prior to the last run) and throw some more timing at it. Right now I run 13* initial, 33* total all in by 2000. Dyno operator suggested bumping initial up to 18 and seeing how it does. I'll have to take note of flash rpm as well on the launch to see how the converter is acting and play with starting line rpm and where the converter works most effectively.
I just had to confirm my thoughts! Thanks gents, I'll update after the weekend! If anyone else has any other pointers, please chime in!
bnsfmachinist is offline   Reply With Quote
Old 04-12-2016, 06:50 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
Why is the cam listed as 2 deg retarded with only 10.5 Comp?
Why such a high leave RPM?
Footbrake lower and hit the converter stall harder.
Might be loosing TQ multiplication of the converter.
I would put a little more timing in it before I re jet 2 lower.
Adger Smith (Former SS)
Old 04-12-2016, 07:26 AM   #5
bnsfmachinist
I retarded the cam 2* in order to have reasonable Piston to valve clearance.
Old 04-12-2016, 04:55 PM   #6
Robert Simpson
Liked 20 Times in 12 Posts
I like your build but I have some questions. Have you taken a cranking compression yet? If so what is the psi? If not I suggest you do that, warm it up, remove the plugs, disable the Ing., and block the carb open. Check and see what the cranking comp is. If it is low say 150psi or under the cam is to big. If it is allot higher closer to 200psi then you have other issues. I believe that the cam and the heads are to big. What you are describing the engine does not have enough bottom end. A RPM intake would help some as would the rear gear, also if you could put in a lower gear in the trans that would help also. I am just suggesting this, I am not being critical of your build just trying to help. Let me know. Thanks
Robert
Robert Simpson is online now   Reply With Quote
Old 04-12-2016, 06:31 PM   #7
bnsfmachinist
I appreciate the suggestion! I'm new to actively participating in this sport and this is my first purpose built drag engine. The car is going together as a bracket car with the hopes to build it into a SS/GT car. I've got a long road ahead of me filled with successes, failures and setbacks! But I'm passionate about the sport, I've grown up in a weekend warrior family and I'm finally at a point in my life to where I'm able to participate!
Anyway back to technical aspects!
I will certainly do a cranking compression test, I'm interested in the points you bring up. I got the heads from my dad who had them ported back in the 80's by AFR, I don't have the flow chart in front of me but I want to say they flow in the neighborhood of 400cfm @ .700 on the intake and 350 on the exhaust? I haven't looked at that chart in a while but I know they're big numbers. So, I figured a big set of heads is going to want a lot of air and fuel, so thus picked out a pretty big solid cam. The rest of the build follows what seems to be a pretty typical 351c mild/moderate build based upon browsing 351c.net and other ford forums.
Again, I'm new into this world of engine building so I more than appreciate advice, pointers and suggestions. I'll get on that compression test when I get an opportunity. I'm a Union Ironworker 40+ hours a week, husband and father of 3 24/7, ain't always easy to get out in the garage these days!
Thanks again guys!
Old 08-28-2016, 06:07 PM   #8
blasttime
blasttime's Avatar
X2 on everything
blasttime is offline   Reply With Quote
Old 08-29-2016, 10:36 AM   #9
Run to Rund
Liked 54 Times in 27 Posts
I agree with the above advice. When I read the initial post, I felt the carb was too big, the intake too aligned to high rpm (especially depending on how it was ported), and the rear gears too mild. Yes, the carb and intake may match the ported heads, but the overall result is consistent with a high rpm combination, and is being killed by a low rpm combination elsewhere.
Old 08-29-2016, 12:53 PM   #10
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Question Re: Lazy off the line
How much total timing do you have dialed-in....all in by??
Dave Turner
SS/GT #1153
