Old 04-16-2016, 08:49 PM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Ford vs Chevy Build-up
Arrived late at Bowling Green today and only got one qualifying run. The injector/MAF swap proved to be only a marginal improvement. First pass was a 13.56 @ 96.42mph. I glanced at the afr gauge thru the lights and it was showing 11.6...far from the desired 13.5 afr.
Before first round I pulled 12 percent fuel across the board and was going to lower the fuel pressure a bit, but it was already below 40psi. Next pass only improved to a 13.51 @ 96.80mph. I'm thinking the next time I have this junk out I will remove the controller completely and run it on the stock ecm for effect...just about out of ideas here.
Rich Taylor
I/SA - 321
Old 04-17-2016, 09:34 AM   #2
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Rich, knocking off 2 seconds isn't too bad, Lol. Seriously though, how much timing are you running ? 30 degrees total is a pretty good start.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 04-17-2016, 11:07 PM   #3
HandOverFist
Oops...edited that second et.
Rich Taylor
I/SA - 321
Old 04-18-2016, 07:15 AM   #4
hutt1
Rich it was good to see you this weekend. Thanks for the video and the pics of the car.. It was a great learning experience for Nick an the car.. Hang in there with yours it will get there. If we can help in anyway let me know. Scott
hutt1 is offline   Reply With Quote
Old 04-18-2016, 08:17 AM   #5
HandOverFist
Thanks Scott...like we briefly discussed this weekend, I believe I will take that controller out of the loop and see what the factory ecm does for afr's.
Rich Taylor
I/SA - 321
Old 09-03-2016, 01:52 AM   #6
HandOverFist
Took the Mustang to the track this evening to try and improve one last time...no joy. It seems no matter what I adjust it makes no difference, even with wild swings with fuel or timing.
Injectors swapped for 19's and a stock MAF sensor...checked phasing for rotor as well. I'm beginning to wonder if this controller is defective...the only thing I did not try this evening is bypassing the controller completely and run it on the factory ecm alone.
I made about ten passes total...the last five the track went away and it spun the tires badly every time. Best et was 8.54 and lagged to 8.70's as the starting line went to hell. My data logger proved to be finicky as well all night...no conclusive data to review. It appears this one will have to go to a chassis dyno along with someone experienced with this efi to ever get it sorted out. I'm totally disgusted right now with the entire deal. Such a shame as this is the easiest combination to drive that I have ever sit in...cuts killer lights time after time.
Rich Taylor
I/SA - 321
Old 09-03-2016, 06:52 AM   #7
jcw31
Liked 6 Times in 6 Posts
10 passes and you didnt bypass the controller,should have tried.Dont give up yet,maybe a chassis dyno is the right thing to do.
jcw31 is offline   Reply With Quote
