Old 03-20-2016, 05:25 PM   #91
Default Re: 79 Mustang project U/SA
Originally Posted by BLIND MULE View Post
Put a NERF football in the right spring seen it before?????? NO JOKE! Does it work don't know!
If your 302 runs like mine it won't make enough power to lean to the right LOL!
I like it! Dime Rocket tip of the year..so far!
Old 03-20-2016, 07:25 PM   #92
BLIND MULE
BLIND MULE's Avatar
Send me a dollar! LOL
BLIND MULE is offline   Reply With Quote
Old 03-29-2016, 12:13 PM   #93
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Well I got a little more done so i thought I would post it. I got the new rear end under the car and got the engine bay cleaned up and painted. Ready to install the K member and front suspension next. Also got the heads checked for cracks and off the the shop to get them done.
ID:	33165   Click image for larger version
Old 03-29-2016, 12:49 PM   #94
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
This is amazing..
U/SA National Record 12.94 seconds at 101.16 mph
Set by BJ Graham in a 76 Ford in Tuscon, AZ Feb 21, 2016.
R/SA and T/SA are at 13 flat by Briaine Philbrick 76 Monza
and Don Lisell's 77 Caddy which is pretty damn good.
But a 12 Second U/SA...wow !!
Guess V/SA is next to figure out how to run a 12...
Here is a prediction; All Mack will eventually find an 11sec ET in Q/SA.
Dan
Old 03-31-2016, 09:54 PM   #95
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Didn't a V/S (stick) Chevy truck with V6 run high 12's to be the #1 qualifier at Indy few years ago?
Will Lamprecht
I/SA Impala still in progress, but close!
Old 04-12-2016, 04:41 PM   #96
ShadowLands
ShadowLands's Avatar
Last two suggestions , in conjunction with one another, work well.
Heat the outer casing with a torch until the rubber pops out, then fold the casing in with an air chisel and push it right out . No chisel marks that way.
Just don't let the EPA see you do this.
If they are seen on my land I can guarantee they'll never be seen again.
We used the torch method too. Someone mentioned toasting marshmallows over the burning rubber until I said I wouldn't be taking them to their chemotherapy treatments if they did.
ShadowLands is offline   Reply With Quote
Old 04-19-2016, 07:38 AM   #97
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Cool build you have going on there RobbieRacer. I enjoy reading up on your progress.
Years ago I had thought about building a '78 Fairmont boxtop with the 302 / C4 combo
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 04-19-2016, 07:40 AM   #98
ALMACK
ALMACK's Avatar
This is amazing..
Dan
Hmmm....might be a new goal.
The closest I ever came Dan as a Q car was a 12.36 in 2013, and that was my very first pass ever in NHRA Stock Eliminator.
Too bad I did not back up that run or it would have been the record.
I/PS '95 Mustang GT
Old 04-19-2016, 10:28 AM   #99
Dan Fahey
Dan Fahey's Avatar
AL...you took a non standard combo and made it rock !
After you cut a 11 second ET you will become famous !!
THEN after that NOW what are you going to do?
D
Old 05-15-2016, 07:52 PM   #100
RobbieRacer
It's been a while but I getting things done. I got the front end back together and got the front brakes done. These are the rims I will be running but the tires are going away. I put the car on blocks so I have more room under it. Next project it welding in the sub frame connector's.
ID:	34102   Click image for larger version
Name:	0515161018 (640x480).jpg
U/SA
79 Mustang
