Old 04-26-2016, 11:39 AM   #3
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Using throttle stop and starting line enhancer
I always use my starting line enhancer when running Super Comp. Stage with my foot to the floor, and the car goes to WOT as soon as I set the transbrake.
You need to change the enhancer setting to make it work that way instead of going WOT 0.8 or 1 second before transbrake release, as it does while bracket racing.
At any rate, yes, you can use both on a run.
S/ST 51
S/C 53
