#11 | |
That's what 2 MSD techs told me... Its hard for me to 100% believe but I will find out one way or another... Its down to this bracket needing to be bolted to the motor instead of the motor plate, and with a new bracket, or the balancer... |
#12 |
#13 |
Liked 333 Times in 180 Posts
SORRY -- missed that part about the trigger was just looking at the pointer and timing mark---FED 387 You are correct
#14 |
The statement that the distributor has nothing to do with the timing when using a crank trigger is ridiculous. How do you think the spark gets to the plug wires??? oh yeah, that is also where the timing light gets it trigger..... It is correct that the point of the crank trigger is to get an accurate timing signal by taking the timing chain variation out of the equation. However, that is only the pickup side of the equation. Unless you are using DIS, the distributor is still in the equation and it is driven by the timing chain which does have slack and does stretch. Every chain driven engine will have 1-2 degrees of slack which will retard the timing...if it gets much more than 3-4 then time for a new chain. That is why MSD is telling you to time the motor at 3000 or more, you have the slack out of the chain at that point. Your vibrating bracket doesn't sound good either, but I think you are trying to fix normal operation if you are looking at timing in an unloaded (idle) to loaded (high RPM) comparison.
Ron Finney 396V S/C Last edited by Ron Finney; 07-09-2016 at 07:59 AM. Reason: typo |
#15 | |
Liked 348 Times in 152 Posts
Phil Molski PMR Performance S/C 1623 |
#16 | |
Ron Finney 396V S/C Last edited by Ron Finney; 07-11-2016 at 05:30 PM. Reason: additional info |
