Old 08-29-2016, 11:10 PM   #11
HP HUNTER
Liked 372 Times in 129 Posts
Default Re: 1971 Buick 455 GS F/SA G/SA Build
Thanks!
Old 08-30-2016, 11:37 AM   #12
goinbroke2
Liked 393 Times in 153 Posts
Just throwing this out there...I see you're testing at 600rpm per sec (which is standard) did you (or would you consider) dynoing at 300rpm/sec? The reason I ask is it has a heavy rotating assembly and a super steep gear might actually slow it down as too much torque wasted spinning up the heavy internals?
Like I said, just throwing it out there....food for thought as it were.
Old 08-30-2016, 09:53 PM   #13
HP HUNTER
I did test at 300 RPM/sec, not much difference in power output. The fast F/SA Buicks 315/330 HP run a 4.30 gear and turn 6600 RPM in the lights, and run 10.80s @ 450 elevation. Its important to note the 315/330 is a whole different animal than Jason Lines C/SA combination.
Old 08-31-2016, 09:12 AM   #14
pfordamx
Liked 7 Times in 5 Posts
In stock your not suppose to be able to do anything to the heads and intake besides a valve job right? although judging from your other post and that you seem to have a in house dyno and who knows what other equipment your probably perfectly capable of altering that to your advantage.
pfordamx is offline   Reply With Quote
Old 08-31-2016, 07:50 PM   #15
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
Jason Line 70 Buick Gran Sort 10:45 in C/SA at Indy this week!
Old 09-01-2016, 01:06 PM   #16
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by stage1scott View Post
Jason Line 70 Buick Gran Sport 10.45 in C/SA at Indy this week!
Jason Line qualified 60/128 at -0.950 under his 11.40 Index
Old 09-02-2016, 07:09 AM   #17
goinbroke2
and your questioning his integrity why?...........
Different valve angles and seat width effect flow, and that's just as two examples of what he meant by "work on the heads". There are many more legal things to do before resorting to "port the heads and cover it up" as you're insinuating.
Uncalled for imho, there are a lot of people with a lot of equipment, doesn't mean they must be cheating because they have fancy tools.
Old 09-02-2016, 10:11 AM   #18
HP HUNTER
Thanks, but I took no offense and never thought anything about it. I asked people for their opinions and really want to here them. I will say this, this forum going to see everything I do to this car-from start to finish, all the engine work including head work-to the dyno testing to the in car testing, I've never seen anything this complete on here before, should be interesting.
Old 09-02-2016, 10:21 AM   #19
HP HUNTER
How would your intake valve job look like on a .398 lift? Anyone.........
Old 09-02-2016, 01:44 PM   #20
Chuck Garey
Liked 10 Times in 7 Posts
Just wondering where you got the car? I ran the same combo in the past I have a good set of 71 heads TA SS valves with Poston springs off the car along with a few other parts. I am located in Texas now formally Va.
Chuck Garey is offline   Reply With Quote
