#1 | |
How much compression do you want to lose? What are the bore/stroke, dome cc's, chamber cc's you're working with? Solid or hollow domes? I would never run a naturally aspirated engine with that much piston to head, unless it were a flat head or Hemi as mentioned. You can work a chamber shape and volume, lose some dome (best option), sink the valves or use a tulip style.....???? Help us out here with as much specific information as possible.... |
#2 | |
Using the stock gasket I come up with about 13.5 to 1 compression. The piston was sent back to the manufacturer to cut the valve reliefs as much as possible and shave the dome. With the stock gasket I'll only have 0.030 piston to head clearance. 0.60 piston to valve with the smaller of the cams that are available to me at this time Using an .080 head gasket will lower my compressiom ratio by over a point, give me 0.70 piston to head (quench area) and allow me to use a couple of larger cams. The next motor I build I'll have a piston made without these froblems. But for now I'm going with these. Called Cometic today and ordered a gasket from them 0.74 thick. I'll yrt 2 gaskets after I get the the running and dialed in. For now It's one less thing to worry about.
Art Leong 2095 SS |
I see, it's a clearance issue more than compression.....
I get a difference of near 2 (1.9) points adding .040" on the gasket. Gotta do what ya gotta do, watch your tune up on that one. Good calculator tools here.... http://users.erols.com/srweiss/index.html#jcalc |
Dave the calculator I used ( http://www.slowgt.com/Calc.htm ) gave me a slightly different reading (about a full point lower). Now I'm not sure which one is right?
I was under the thought that my compression was 13.58 to 1 with the 0.40 head gasket, and about 12.16 to 1 with the 0.80 gasket. Can anyone take a look at which calculator is correct? There are only a few cams for the motor I'm using I don't want to go way up on the compression to start off plus the larger cams might have piston to valve issues. The overhead cam is probably more forgiving than a pushrod motor Due to very little weight. But I want to shoot for at least 0.060 The larger cam is .492 at the valve. The smaller one I'm using is .453
Art Leong 2095 SS |
Liked 883 Times in 237 Posts
Art, I use the calculator Dave uses. ...I also use Challenger engine software. ... Both programs came out with similar numbers,altho higher than yours, using the specs you posted. . .....You didn't spec the gasket bore, but assuming it is 3.520"i.d., both programs indicate 14.25 to 1 compression with the .040" gasket,and 12.75to1 with an .080" gasket, if the 7.5cc dome volume is the net volume,including the valve reliefs ......Tom
The 7.5 cc number is the total dome displacement counting valve releifs and the piston flat area being 0.10 out of the hole. I poured the cylinder with the piston .500 down the bore. Got the volume of the bore and stroke times .500 then subtracted the volume from what I had measured. That was my dome volume.
The head gasket is 3.490. I guess I'll have to run the thick gasket. 14+ comp ratio will be way to much for the cams I'm running but I can play with overlap due to 2 cams.
Art Leong 2095 SS |
I think the Weiss calculators are pretty good, within a couple of tenths on the ratio.
You should be able to come up with a good number for the gasket, I didn't have the bore size on it, but catalog gaskets have the cc's calculated. Don't forget to plug in the "-.010" for the piston out of the hole. |
