Dave, Give me a call and I tell you what I think is going on here.
Liked 223 Times in 73 Posts
This is a .120" thickness gasket that I tried out today. It does a world of good for my alignment issues! Unfortunately the port openings are rather large for a little 283.
Does anyone know a manufacturer (hopefully with part number) that makes gaskets .120" thick with port openings in the 1 7/8" to 2" range? I can use these if I have to, but I'd rather find something that is a little closer to the actual port size. So far my search has come up empty. ![]() Last edited by Dave Muller; 07-08-2017 at 02:10 PM. |
Liked 169 Times in 53 Posts
see about a fel-pro 1245.
Bill Bogues 4696 STK |
#5 | |
Cometic made me some thick intake gaskets for my 327 stocker that had a similar issue.
I never did any for my 283's but I am sure if you gave them specs and ordered a few they would do it Quote:
James Schaechter 3163 STK |
This looks a lot better!
![]() Last edited by Dave Muller; 07-08-2017 at 02:09 PM. |
Okay, the manifold is back on, and as a test I dropped in the distributor with no gasket. I measure an .026" gap between the bottom of the distributor and the manifold.
![]() Here it is with an .030" shim and a gasket. ![]() Hopefully it'll stay together a little longer this time. ![]() Last edited by Dave Muller; 07-08-2017 at 02:12 PM. |
If you don't think that gasket material will hold the distributor at the right clearance, I have seen valve spring shims used for clearance. Might have search to find one the right size but might give more peace of mind. Nice build.
Liked 719 Times in 220 Posts
Seems to me, the FelPro blue distributor base gasket seems to work as well as any for a combination gasket and spacer. The cheap gray fiber gaskets swell up and get soft after a while. Great build!! The valve spring shim is a brilliant idea. Just finding one the correct ID is the game.
