#11 |
Liked 1,603 Times in 583 Posts
This is the actual language on the 2017 rule change.
It's not clear enough and it needs to be explained better. It does not say that hydraulic lifters can be replaced with solids. It still gives the requirements for checking hydraulic lifters. |
#12 |
Liked 508 Times in 92 Posts
If I misunderstand this change, sorry! The guys who use solid lifter engines are getting screwed over do to no chance on manipulating the lifters. It's bad enough that .010 in a hydraulic is considered OK by NHRA. The engines HP were based on the lifter working the way the manufacturer designed it, not the way they are now with a built in lash. Might as well let everyone use solid roller cams and get over with it.
Casey Miles 248H Stock |
#13 | |
I'll have to call my law firm , Dewey, Screwum , and Howe, and get an interpretation.
#14 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
#15 | |
Liked 186 Times in 57 Posts
John Ancona 717 STK / SS |
#16 |
Liked 1,874 Times in 422 Posts
Yeah, give everybody solid rollers.
Then next year, give everybody 0.700" lift. ![]() A couple years down the road, wonder why you have a 9" tire Super Stock class, spiraling out of control.
Alan Roehrich 212A G/S |
#17 |
Liked 403 Times in 158 Posts
Alan, I was thinking the same thing...stock lift but any duration...and roller rockers....and now solid lifters...and.....
All them "hyd" motors are going up in rpm now! |
#18 |
Liked 7,807 Times in 1,748 Posts
A couple years down the road? That ship sailed a long time ago.
#19 |
Liked 535 Times in 110 Posts
X2. If you want roller lifters, go buy or build a SS car!
Jim Kaekel 3836 STK |
#20 |
Liked 719 Times in 220 Posts
All I saw in the rule revision was an amendment allowing what has been accepted for years. Ceramic based lifters or coated tool steel lifters are not new,as we all know.If your combo came OEM with rollers, use rollers. If it didn't, does this language imply or specify a change over? I didn't read that.Accepted lifters for the last 10-15 years,be they ceramic based or coated steel, were still an OEM configuration. Running even OEM valve trains with lash isn't new either. What does this revision possibly change?
