Old 12-08-2016, 04:04 PM   #61
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Lifter rule in Stock
I seriously doubt if there is much advantage for people who are maxed out on camshaft technology on their hydraulic lifters. The ramp profiles on those cams are taking assuming that after .015" lifter rise, the lifters are solid anyway. You might be able to speed up the first 6-10 degrees of the ramp a bit with a solid lifter and drop it a bit quicker. One thing for sure, there will be a lot of camshafts sold next year!
Old 12-08-2016, 06:25 PM   #62
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
I don't see a performance improvement with solid flat tappet lifters to replace hydraulic flat tappet lifters.............
A solid lifter would still have to modified to work with the spring pressures that a run now.....
The ramps are so fast that they almost hit the edge of the lifter now.....
If you ran tool steel, shoeboxes or whatever hydraulic lifters you would still need the same type of treatment or design to make it live......
The main advantages that I can see are a lower price for solids over hydraulics and if you wished, an EDM hole could be used for addition oil supply....
That said.............
How about allowing the front battery in stock to be relocated to the trunk so that you haven't a hot battery lead that is 12' long going from the battery disconnect to the front battery. Even with the disconnect off the 12' long battery cable that is capable of carrying more than 500 amps straight to ground if the cable is damaged is hot...If something bad happened and the fuel system were damaged and leaking the battery and cable are still in the engine compartment and hot..........
Just my thoughts because it would make the cars safer, easier to wire and lighter....
Thanks,
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 12-08-2016, 08:09 PM   #63
Mike Gray
Mike Gray's Avatar
Liked 691 Times in 199 Posts
Originally Posted by Bob Mulry View Post
Hi,
Thanks,
Bob
I thought a battery disconnect was not necessary for a single front mounted battery?
Mike Gray is online now   Reply With Quote
Old 12-08-2016, 10:28 PM   #64
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
NHRA tech department clarifies recent lifter rule change
The change is to allow the use of a solid lifter in place of a hydraulic; you may not replace a flat tappet with a roller.
So what effect if any would there be on a 1993 build chrysler hydraulic lifter on a 383 big block. I assume new valve springs would be needed. Didn't change the rockers, still original as delivered.
Thanks
Eric
Eric Merryfield 1883 STK
Old 12-08-2016, 11:18 PM   #65
Coleydog
Liked 53 Times in 38 Posts
Thanks
Eric
Can't see why new springs would be needed, better have adjustable rockers though. I thinking solids are lighter than hyd. anyway. Also a lot cheaper.
Old 12-08-2016, 11:40 PM   #66
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
I am glad I run Pure Stock!
Old Stock without any of today's issues!
D
Old 12-09-2016, 02:49 AM   #67
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
No, not for a single front. But with a front mounted and a rear mounted batteries, the disconnect has to kill a running engine.
Dave Noll, EF/S ,?/SA 6526
Old 12-09-2016, 11:16 AM   #68
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Probably 95% of hydraulic cam stockers have solid lifters already and have had for many years,they just have .015'' travel in the pushrod seat and are considered hydraulic by the rules,it is a solid lifter with the pushrod seat cut for .015'' travel,nothing hydraulic about it and .010-.012'' of that travel is taken out when the valve is set depending on lash the lifter is compressing .003-.005'' the only difference is the lash is between the pushrod seat and lifter body rather than between the cam and lifter.
This rule doesn't change the need for ceramic,tool steel or whatever kind of special lifter is being used,it doesn't change the cam profiles they are already solid lifter profiles.
Only thing it changes is a hyd. roller that has a true hyd. roller lifter which has probably been modified to only have .015'' travel will now be able to take them out and replace with a much lighter solid roller lifter,which won't make any difference because they are already running a spring strong enough to handle the extra lifter weight,so maybe they get a few more runs out of their springs.
Nothing to get excited about.
Mike Taylor 3601
Old 12-09-2016, 11:54 AM   #69
cmracing
Liked 62 Times in 29 Posts
Hi,
Thanks,
Bob
I wire a car the "correct" way so there is no "hot wire" from front to back when the switch is off in the back with a front-mounted battery also. PITA, a lot of extra time and $$$, but it is legal, it works, and kills the engine when the switch is pushed in.
cmracing is offline   Reply With Quote
Old 12-09-2016, 12:05 PM   #70
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I agree ^^
All my cars with rear mounted batteries are wired this way. That big fat welding cable running up the side of car is only hot when the starter is kicking over.
Years ago I wired a rear mounted battery the way NHRA shows and that fat wire shorted out and caught on fire. Bad idea.
Ever since then I have wired it this way in the diagram... the correct and safest way...( note that the switch still kills every functioning item on the car when switched off )
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
