Old 12-31-2007, 09:32 PM   #1
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: TH200 parts
SS/3011,
You are exactly right about the tranny mount.. The last time I broke a case I was using a solid mount, never again.. The tranny needs to flex a little or you will have nothing but problems..
No- problems with trannys since, the other thing to do is an engine strap on drivers side, that also helped.... Good luck, Dave,
Dave Ribeiro 1033 STK
Old 12-31-2007, 11:55 PM   #2
Grant Eldridge
Grant Eldridge's Avatar
Default Re: TH200 parts
Ditto on rubber rear mount and torque strap on driver's side of motor. With those, the side brace and cast pan have had no further case problems. One other problem area could be the stock cast stator support on the front pump. I've broken one, and a local Firebird racer has also experienced that failure using the TH-200. Jim Mantle has a fix he's developed for that by re-machining the pump to accept a specially modified steel stator support......
Grant Eldridge is offline   Reply With Quote
Old 01-01-2008, 06:32 PM   #3
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Thank you all, We've been die hard th350 users, but areg oing to try this 200, and i never would hve thought something as simple as a cast pan would help he case live, but it makes sense now!
Thanks again, Chris
Old 01-02-2008, 12:07 PM   #4
john kilgore
john kilgore's Avatar
th 400 cases are not none to breakage. good luck jk
John Kilgore Transmissions
PH-818.767.4480
john kilgore is offline   Reply With Quote
