Old 02-26-2017, 08:13 AM   #61
nickh
nickh's Avatar
Liked 659 Times in 197 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
That being said, I don't think I've seen a tech guy shine a flashlight down inside a door, in about 40 years.
You'd be lucky to find all the window regulators in 2017.
Mark, that is exactly what I was thinking have never seen tech look at that not in div 4.
Cool build looks like it would be a blast, think outside of the box and read every line of the rulebook.
Old 03-10-2017, 02:09 PM   #62
Jeff Stout
Liked 706 Times in 283 Posts
[URL=http://s666.photobucket.com/user/my1haywood/media/20170310_105952.jpg.html][/URL
Finally getting started. Long over due. Car came from Orland Park IL, hence the surface rust. Removing nearly full gas tank. Will get fuel lines removed and rusty brake lines removed today.
Old 03-10-2017, 09:55 PM   #63
HP HUNTER
Liked 373 Times in 129 Posts
Whens Kelley going to get started on the engine?
Old 03-10-2017, 10:50 PM   #64
Jeff Stout
I hope next week Ill pull motor out from under workbench and take apart.
Old 03-11-2017, 11:49 AM   #65
Who's Kelley?
Old 03-13-2017, 07:50 PM   #66
Rick Unterseh
Rick Unterseh's Avatar
Liked 31 Times in 7 Posts
Hmmmmm with more of these U/SA cars being built, maybe I need to build one, I have an extra Astre in the backyard
Rick Unterseh
O/SA
P/SA
Rick Unterseh is offline   Reply With Quote
Old 03-13-2017, 09:32 PM   #67
Jeff Stout
Gently used set of 30x9 slicks 125.00 for pair. 3337.00 total. Tried getting rear end out today. Little torch work and will be out tomorrow.
Old 03-14-2017, 08:09 PM   #68
HP HUNTER
Who's Kelley?
Kelly wanted me to post WFO, he said you'll know.
Old 03-15-2017, 01:14 PM   #69
Jeff Stout
Finally removed rear end. Took alittle torch work but its out. Bought rear control arm bushings from Speedway. $101. Total $3438
Old 03-15-2017, 10:24 PM   #70
S/ST J718
WFO .... wow.... you should get a great build , always like wagons! Been watching so far, keep it up its a lot a fun watching ....
Old Nick in Tucson! Hahaha
S/ST J718 is offline   Reply With Quote
