Old 04-01-2017, 02:35 PM   #11
J&S Racing
Liked 319 Times in 82 Posts
Default Re: 69 Camaro B/S
It's been a long battle but the steering is finally coming together.
The first problem I had was with the tie rods.... I planned on using the Baer tracker kit but had a problem with the inner tie rods being to long. After a lot if back and forth I decided to build inners. I'm happy how they came out.
I also ran into a issue with the column being compressed leaving a 1/2" gap between the rag joint and flange. We couldn't figure out why since there was no evidence of a front end collision. I think this happened from the body bushings being so bad.
I put a strap around the flange and tried to pull it out with no luck. I was able to slide the column down and everything fits great with no bind.
Gonna tackle the headliner this weekend then she's ready for the chassis shop.
J&S Racing is online now   Reply With Quote
