Old 04-06-2017, 11:53 AM   #91
Paul Wong
Liked 419 Times in 85 Posts
Default Re: Fairmont U/S Build AKA Craigslist Racer
Originally Posted by Shadylane View Post
Since my car is a fairly light, low HP car, I'm hoping they will work. They came recommended by a couple of guys. Guess I'll find out.
Thanks
The radials are a great idea, but it would really make your life a lot easier to start with a bias tire and get the clutch close. Then progress to the radial.
I have noticed the same thing with the radial that 1 out of 5 times it spins bad.
Paul Wong is offline   Reply With Quote
Old 04-06-2017, 07:06 PM   #92
Jim Caughlin
Liked 805 Times in 245 Posts
Radials were a tick faster, as I mentioned, I had to run them down to 10 - 12 lbs to get them to work. My car is low HP and light also, the only difference is that I have a boatload of low gear ratio. I guess my point is that you're not going to win a lot of rounds playing Russian Roulette on which pass they are going to spin. And when they do spin, it's not a recoverable spin, I have short shifted into second and had them continue to spin even then.
Jim
Jim Caughlin is offline   Reply With Quote
Old 04-06-2017, 08:44 PM   #93
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
Jim
I will take your advice and look for some Bias tires to start with and maybe try the Radials at a later date.
Thanks, gentleman.
Shadylane is offline   Reply With Quote
Old 04-06-2017, 09:25 PM   #94
Kelly, I tried radials with a stick, over 20 years ago. Too much torque and too much clutch.It bounced all over the place.
I would revisit that idea on a lighter, lower hp car, for sure.
But the guys are right. You've got enough to think about on the first day out.
Old 04-12-2017, 07:43 PM   #95
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
Wow the car looks great Kelly! keep us posted and good luck!
fred goodwin is offline   Reply With Quote
Old 07-22-2017, 09:19 AM   #96
Shadylane
Shadylane's Avatar
FINALLY! the car is done with paint. I had a real mess with the first guy that painted it. Screwed me and the car pretty bad. Some of it was my fault for not holding him accountable. Anyway a racer friend in Colorado saved my butt by repainting it. I still have to install some emblems and small parts, then it's time to do a lot of testing. Looking at a local race in early August.
Name:	IMG_1082 - Copy.JPG
ID:	40990   Click image for larger version
Name:	IMG_1086 - Copy.JPG
ID:	40991   Click image for larger version
Name:	IMG_1089 - Copy.JPG
Old 07-22-2017, 04:08 PM   #97
GTOMayhem
Liked 22 Times in 14 Posts
Looks great. Good Luck!
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 07-22-2017, 06:44 PM   #98
I'm looking forward to seeing this car on the track.
Junior Stock Lives!
Old 07-22-2017, 06:54 PM   #99
David Lee
Liked 346 Times in 126 Posts
Are you going down to the track in ABQ?
Old 07-22-2017, 07:22 PM   #100
Shadylane
Shadylane's Avatar
Yes ABQ, if i can get a couple of suspension items finished in time. I'm in serious need of some seat time.
