Old 05-02-2017, 08:20 PM   #1
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
Originally Posted by Jeff Stout View Post
Made a mistake today on guessing how much to cut from head to get chamber down to proper CC. Way to far to get back to spec. Had to buy a used head for 60.00 and received cam bearings today 11.50 New total $3555.50
Jeff,
I usually takes about 0.005" ~ 0.006" of deck surface removal per CC of combustion-chamber volume for an Oldsmobile cylinder head.
However, this is a guideline and you need to constantly check it.
Old 05-02-2017, 09:23 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Jeff -
If you have a burette available, PM me and I will show you an easy way to get real close on the CC volume on one cut.
Old 05-02-2017, 09:44 PM   #3
All the new NHRA phony baloney valve job all done, already?
Old 05-02-2017, 10:30 PM   #4
SSDiv6
Old 05-03-2017, 12:47 AM   #5
Jeff Stout
Liked 706 Times in 283 Posts
I went with the .005 per 1 CC and what I ended up with after being to small was .003 per 1 CC. I mistakenly just went for it and didn't check between cuts and ended up 6 cc's to small. So instead of cutting valves seats deeper and try and get back the 6 cc's ( which I doubt I could)I just bought a head. The second head was brought down the right amount and checked during cutting and the .003 per 1 cc worked on this head. Tomorrow the third head will be checked and should be ok. With this being my first time building instead of paying I learned a great lesson.
Old 05-03-2017, 01:01 AM   #6
Jeff Stout
After sitting home tonight thinking about it I'm guessing if I had 2 different thickness head gaskets and the same bore I could have determined how much the 2 were in cc's and used that for a better gauge. Yes No maybe?
Old 05-03-2017, 07:32 AM   #7
HP HUNTER
Liked 373 Times in 129 Posts
But what about your piston to valve..................
Old 05-03-2017, 09:30 AM   #8
Jeff Stout
Cam has not been made and shipped yet. Ive heard from 2 others that valves wont need to be sunk to make piston to valve fit.
Old 05-03-2017, 07:30 AM   #9
HP HUNTER
LOL awwwwww
