Old 05-24-2017, 10:33 AM   #1
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: '66 Malibu N/SA
I would defer to the 3/4 ton for towing. The frame, springs, etc, are usually larger and more adequate for towing.The equalizer hitch is a must. As you know, whether it's Vegas,Phoenix,or Bakersfield ,there's no flat easy tow to SoCal. 20 years agi, I towed my first '68 Chevelle on a small open trailer with a 71 El Camino. Never had a problem, I was just that fortunate.My Suburban handles that open trailer with a car on it like it's not even back there.
Old 05-24-2017, 03:40 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '66 Malibu N/SA
I'm old enough to remember a time when trailers were scarce and considered a luxury item...most race cars were flat towed.
Rich Taylor
I/SA - 321
Old 05-24-2017, 07:55 PM   #3
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Yup, I still have my NMW tow hubs and a tow bar in storage.
Old 05-25-2017, 07:12 AM   #4
Pinballer
Pinballer's Avatar
Liked 13 Times in 7 Posts
Dave,
Congratulations on the build and your successful debut. I'm sure it will inspire another guy or two in the future to take what some might call a literal "mess" of a car and make something fabulous out of it.
Always looked forward to the next installment you had to offer. Don't be a stranger, give us an update now and then on how things are progressing. Best of luck in the future!
Brian Saunders Lerna IL
'79 AMX T/SA 3790 currently being resurrected
Pinballer is offline   Reply With Quote
Old 06-24-2017, 06:36 PM   #5
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Not a lot has been updated on the car as yet, but I have made arrangements to get the pinion angle set and I'm soon to be swapping to a manual master cylinder. Oh, I also got the brake pressure switch adjusted to somewhere near where I'll want it and confirmed that it works.
In the meantime I pulled the trigger on the promised upgrade to the Ranger, and bought a 2016 F-150 with 27K miles. Here it is, for the first time, with the Chevelle in tow. I plan to move the wheel chocks forward a bit for some additional tongue weight, but otherwise I think it's very close. There's in the vicinity of 550 lbs right now, I'm looking to get that to around 700.
I didn't neglect the car entirely over the past month, I removed most of the steel plates that were spanning the frame for ballast and built a weight box. The piece I had available for the top was a little small and I had to extend it with some 1" flat steel, but otherwise it went pretty smoothly.
Dave Muller is offline   Reply With Quote
Old 06-24-2017, 08:39 PM   #6
HandOverFist
Looks good Dave. Yes, if you begin to get some tail wag on the trailer when towing you know it needs some more tongue weight.
Rich Taylor
I/SA - 321
Old 06-25-2017, 04:05 PM   #7
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
Just passing along an old guy trick......
Once you get your tongue weight to what you want, take a look at the rocker link that connects the springs between the front and rear axles on your trailer......
The link should be parallel to the ground and you should adjust the ball height to make that happen.....
That way you will have equal weight on both axles and you won't overload one pair of tires...
Happy towing,
Bob
PS:
This applies to any trailer that has tandem axles with leaf spring suspension with a rocker between the springs...
Bob Mulry 7516 STK
A & M Motorsports
