Old 06-27-2017, 06:46 AM   #1
[QUOTE=LO23;538372]The LO23 looks to me like the same O used below in "DODGE TWO DOOR HARDTOP".
But...... If you look below that at the spelling of Corporation all the O's are full circle!
So regardless of the type set , was the intent to be a " oh" or a " zero"?
I agree with most that think it is intended to be an "oh".
Old 06-27-2017, 10:46 AM   #2
LO23
Liked 5 Times in 5 Posts
[QUOTE=Charlie A;538377]
Yes, but CORPORATION is part of the pre-printed portion of the document, not the part that gets typed in specifically for each vehicle, and would be expected to be a different type-set... my thought on it, anyway.
LO23 is offline   Reply With Quote
Old 06-27-2017, 11:04 AM   #3
TheDane
That is because it is part of the preprinted form, using the font "Futura".
Such fonts was not possible with typewriters or machine writers, as they only worked with "fixed-width" fonts, and because of the fixed width, they couldn't make that much difference between 0 and O.
But if you compare the white areas inside 0 in 55024 and the O in LO23, you will probably aggree that the area is clearly smaller in the 0.
TheDane is offline   Reply With Quote
Old 06-27-2017, 11:38 AM   #4
LO23
You're misquoting here a little- that statement was Charlie A's; not mine. The way it's posted it looks like I said that. I already said that was because of that being part of the preprinted form. BUT- good to know about why the "O"s and "0"s look so much alike, due to fixed-width font. Thanks!
I agree with you completely.
Old 06-27-2017, 01:43 PM   #5
TheDane
Right, sorry LO23.
I intended to quote Charlie A, but as his post include a bracket with "QUOTE=LO23", it mistakenly quoted you. Now corrected.
Old 06-27-2017, 01:58 PM   #6
LO23
Right, sorry LO23.
No worries, thanks for fixing!
Old 06-27-2017, 05:24 PM   #7
Dang....I'm out.
Old 06-27-2017, 05:44 PM   #8
LO23
Dang....I'm out.
Sorry, I know this has been a long, boring discussion, but I truly appreciate your thoughts and input.
Old 06-28-2017, 07:20 AM   #9
TheDane
Dang....I'm out.
Was it something I said...?
