Old 09-05-2017, 09:19 AM   #1
GTOMayhem
Liked 22 Times in 14 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
Originally Posted by Jeff Stout View Post
6.14. with biggest 30x9 I could find. I've been told I should go the other way. 5 something ratio with a 27,28 tall tire but this is what I found for now
OK, stupid question time. What are the advantages/disadvantages to larger vs smaller tires with corresponding ratio changes? Is it because of the low HP engine? Big car?
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 09-05-2017, 09:55 AM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Rick Thomason
GTOMayhem
Some have been saying that I don't need to drag a big tire all the way done the track when I'm a low HP car.
Old 09-05-2017, 11:29 AM   #3
nickh
nickh's Avatar
Liked 653 Times in 195 Posts
Jeff are you looking at the lightweight radial or is that bad for such a heavy car?
Old 09-05-2017, 12:28 PM   #4
Jeff Stout
Not sure if a light weight would be good or bad. I would think good as I can air them up pretty good if the side walls are soft for a heavy car
Old 09-12-2017, 02:45 PM   #5
Jeff Stout
Finlly made my fist trip to scrap yard with metal items I removed from wagon. A whole $50 so I get to reduce new cost to $6812.98
Old 09-20-2017, 02:13 PM   #6
Jeff Stout
Here is a problem I created. I bought these brakes used and the brackets are for big axle bearing which I do not have. So I made this spacer to help support axle flange and bearing, plus seal gear oil from leaking out.
Old 09-23-2017, 03:35 PM   #7
Jeff Stout
What a race car. All slicked up with my bark and twigs paint scheme
Old 09-05-2017, 11:29 AM   #8
Jerry Terry
Jerry Terry's Avatar
Liked 450 Times in 133 Posts
They are probably right Jeff, when i raced the1968 BelAir wagon it was hard pulling those tires but actually we started airing them up a little at a time and we would go faster and it still hooked okay it also depended on the track but it hooked almost everywhere.
Jerry
Old 09-05-2017, 12:25 PM   #9
Jeff Stout
Thanks for the replys. The 6.14 and the 94 rollout tire is what I was able to purchase frugally ( if thats a word) so this is what I have to start with. With altitude here in AZ I figured this much gear wouldn't hurt. Maybe back east it would be to much or Pomona
