Liked 66 Times in 31 Posts
Thanks for all the info. I had all the glass out and on a table. Both side are done and reassembled now. Moving on to the back glass which has defroster lines in it. Not sure they're going to be there when I get done.
I'd be the guy who took the car to the professional refinishers and told them to do whatever they wanted with it. I can't afford to drive an extra day without glass
Sorry to bring up this old topic again, but I would like to say that dealing with old window tinting can be tricky. Instead of using ammonia and a razor blade, you can use a steam cleaner or heat gun to gently heat the tint. This will help loosen it without causing harm. Another option is a spray tint remover or an adhesive remover specifically designed for this purpose. A few months ago, this was the way I removed my tint and started using the sunblinds I ordered from snapshades.com, as they are more convenient for me. Just remember to follow the instructions carefully. Patience and the right tools will help you remove the old tint without any problems.
