Old 03-31-2018, 10:31 PM   #1
Kenny Bomar
Liked 425 Times in 51 Posts
Default AA/sa to AA/s
Well I'm going back to " more fun racing" banging them gears!! I get my new G Force 4 speed Monday I hope to have it all in sync by the SportsNats. Looking forward to rowing down the track!!
Kenny Bomar is offline   Reply With Quote
Old 04-01-2018, 07:16 AM   #2
TOSTO RACING
TOSTO RACING's Avatar
Liked 662 Times in 187 Posts
Default Re: AA/sa to AA/s
Cool! I'm converting my 69 Camaro 427 also to AA/S .
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is online now   Reply With Quote
Old 04-01-2018, 08:35 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Thumbs up Re: AA/sa to AA/s
You guys have got it!!
Old 04-01-2018, 12:53 PM   #4
Nmbr1GMfan
Really is the fun way to go.
Todd Greene
Old 04-01-2018, 08:14 PM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
The only way to go!
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 04-01-2018, 10:03 PM   #6
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Great choice on the G Force! You will love it!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 04-03-2018, 12:21 AM   #7
Kenny Bomar
Hidy joe any particulars I need to know about the g force I ran a jerico for 8 years broke the main shaft once but other than that ok . Most tell me the g force is better ? Doing good for u I guess?
Old 04-03-2018, 11:35 AM   #8
Joe Martens
Kenny, make sure you check your end play so that your input shaft is not bottoming out against the pilot bearing. The splines are longer on the G Force and could cause a problem. The cure is to just run a spacer between the block and bellhousing. Also, depending on which Jerico you ran, their common length transmission is 2 inches longer than a G Force, although they make a shorter version which would be the same as a G Force. Other than that you should be good to go!
Let me know if you have any other questions.
Old 04-04-2018, 12:12 AM   #9
Kenny Bomar
Thanks joe I'm using the McLeod bell housing it is really nice I heard u had to space the QuickTime bellhousings because they are made too shallow I used a Lakewood w the jerico, I haven't started assembling yet I hope my drive shaft is right. Btw how hard do u have to pull the stick w the G force? I've had some tendinitis in my right arm lately but it is better. Like a friend of mine said "getting old and living for Jesus isn't for wimps!" I'll b 70 this year and I'm thankful I can still get out there and play!
Old 04-04-2018, 11:55 AM   #10
Joe Martens
Kenny, call me when you get a chance. 440-897-9769.
