Old 04-18-2018, 10:44 PM   #1
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Need more P/V clearance in a BB mopar
What method did you use to figure out your clearance ? Clay with full valve springs , or dial indicator with a light checking spring ?
Old 04-19-2018, 07:33 AM   #2
Liked 10,767 Times in 2,238 Posts
Use more deck clearance and keep the gasket thin. You will need about .035 '' total to keep pistons from contacting head. Have P/V clearance through the range of adjustment, so you can roll the cam forward or backwards without bending stuff. Exhaust valve will like to make contact in split overlap.
Old 04-19-2018, 08:17 AM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Having the correct cam timing is more important then losing a half a point of compression.
Old 04-19-2018, 08:19 AM   #4
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Checking springs, with an indicator on the retainer
I've already moved the cam around to give me the most intake clearance, which has been the biggest problem, and still have around twice that amount of exhaust clearance.
Piston is .010 in the hole, spec is .004. I'm leaning on leaving the valves alone and using whatever gasket gives me the clearance needed. Those 2 together should give me the .035 Larry mentioned.
In hindsight, I should have gotten a smaller cam so I could keep some compression........
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 04-19-2018, 08:48 AM   #5
Chevy55
Banned
Liked 179 Times in 89 Posts
Cut the valve face a few thousands.
Also the cam could be ground to twink the duration, you won't lose compression and horsepower loss is negligible.
Chevy55 is offline   Reply With Quote
Old 04-19-2018, 09:43 AM   #6
ss3011
ss3011's Avatar
Indicator method is good , but usually gives the closest value . When the real springs are used the clearance will be greater . Would be nice to be able to run the cam advanced , but that would be based on dyno testing .
Old 04-19-2018, 10:26 AM   #7
Glenn Briglio
As Russ says, check with actual spring pressure. You'll have more p to v clearance.
Old 04-19-2018, 02:09 PM   #8
GallopinGhost
I think for now we'll leave the valve job as is, I'd hate to lose anything there. I really just need to decide how much to deck the head. Once I get the head from the shop, I'll check it with race springs and see where it's at. Then I'll just get a gasket that will give me what is needed. This project is taking forever and I just want it on the track. Next winter I can do some of the trimming of the valve head and maybe re-grind the cam, hopefully that will enable me to then get a thinner gasket and get some of the compression back. thanks all
Brian Carpenter
Stock 1358
Old 04-19-2018, 10:24 AM   #9
Glenn Briglio
Done it both ways, more compression and less than ideal cam timing and vice versa. Cam timing always more important than compression.
