Old 04-19-2018, 08:48 AM   #1
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: Need more P/V clearance in a BB mopar
Cut the valve face a few thousands.
Also the cam could be ground to twink the duration, you won't lose compression and horsepower loss is negligible.
Chevy55 is offline   Reply With Quote
Old 04-19-2018, 09:43 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Indicator method is good , but usually gives the closest value . When the real springs are used the clearance will be greater . Would be nice to be able to run the cam advanced , but that would be based on dyno testing .
Old 04-19-2018, 10:26 AM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
As Russ says, check with actual spring pressure. You'll have more p to v clearance.
Old 04-19-2018, 02:09 PM   #4
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
I think for now we'll leave the valve job as is, I'd hate to lose anything there. I really just need to decide how much to deck the head. Once I get the head from the shop, I'll check it with race springs and see where it's at. Then I'll just get a gasket that will give me what is needed. This project is taking forever and I just want it on the track. Next winter I can do some of the trimming of the valve head and maybe re-grind the cam, hopefully that will enable me to then get a thinner gasket and get some of the compression back. thanks all
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 04-21-2018, 08:15 AM   #5
Liked 10,763 Times in 2,237 Posts
While you are waiting on next winter find out what is available for gaskets, pistons, rods, and block deck height. In your spare time learn how to juggle. lol
Old 04-21-2018, 08:28 AM   #6
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
The Steel Shim head gaskets for a small block are very hard to find, the Mr. Gasket head gaskets are .028, about as thin as I have found. Might not be able to get the .021 gaskets you mentioned. I was taught not to sink the valves. So I wouldn't personally do that if there was another solution.
Patric Fox is offline   Reply With Quote
Old 04-21-2018, 12:23 PM   #7
Coleydog
Liked 53 Times in 38 Posts
Well Brian looks like we're in the same boat. Someday you and I will get these cars done. Look out world. LOL
I need to get down there a take a look see.
Mike
Old 04-21-2018, 08:27 PM   #8
GallopinGhost
I'm enjoying the juggling match now, but then again, I don't have a running engine yet. Lol
Brian Carpenter
Stock 1358
