Liked 239 Times in 114 Posts
Indicator method is good , but usually gives the closest value . When the real springs are used the clearance will be greater . Would be nice to be able to run the cam advanced , but that would be based on dyno testing .
Liked 974 Times in 310 Posts
As Russ says, check with actual spring pressure. You'll have more p to v clearance.
Liked 21 Times in 13 Posts
I think for now we'll leave the valve job as is, I'd hate to lose anything there. I really just need to decide how much to deck the head. Once I get the head from the shop, I'll check it with race springs and see where it's at. Then I'll just get a gasket that will give me what is needed. This project is taking forever and I just want it on the track. Next winter I can do some of the trimming of the valve head and maybe re-grind the cam, hopefully that will enable me to then get a thinner gasket and get some of the compression back. thanks all
Brian Carpenter Stock 1358 |
Liked 10,769 Times in 2,238 Posts
While you are waiting on next winter find out what is available for gaskets, pistons, rods, and block deck height. In your spare time learn how to juggle. lol
Liked 11 Times in 8 Posts
The Steel Shim head gaskets for a small block are very hard to find, the Mr. Gasket head gaskets are .028, about as thin as I have found. Might not be able to get the .021 gaskets you mentioned. I was taught not to sink the valves. So I wouldn't personally do that if there was another solution.
Liked 53 Times in 38 Posts
Well Brian looks like we're in the same boat. Someday you and I will get these cars done. Look out world. LOL
I need to get down there a take a look see. Mike |
Liked 2,487 Times in 698 Posts
I am confused.......How can you tell piston to valve clearance BEFORE
you CC Heads and know how much they will be milled. It is not unusually to mill BB Mopar heads .060 or more to get the correct specs. Every thousand you mill them bring them closer to piston. How can you measure accurately piston to valve prior to finishing the heads that are actually being used on engine What did I misread on this post?
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-21-2018 at 05:19 PM. |
I'm enjoying the juggling match now, but then again, I don't have a running engine yet. Lol
