Old 04-22-2018, 11:49 AM   #1
Default Re: 12 Bolt vs 10 Bolt Rear
Originally Posted by Rick Schilling View Post
Generally the B bodies with the Baby LT-1 or 305 have the smaller rear. The LT-1's generally have the 8.5 (Impala and Caprice).
Shhhh..Don't tell Dan. He's spent too much time on the SS forum, and not under those cars.
Whatever you do , don't tell him the early Chevelles did not have the same suspension. Although it looks similar, it is not a metric configuration.
Also , I have never seen a bolt in 12 bolt for those cars. Maybe those SS guys can help him. Apparently we are not qualified here.
Old 04-22-2018, 08:48 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
You are right again....bluster blossom...
I am not under my car often...and that is a good thing!
and It helps to have a Forum to share experiences!
Mark you car is so slow.
It’s shadow waits for you at the end of the strip !
Dan
Old 04-22-2018, 09:09 PM   #3
MR DERBY CITY
Liked 8,213 Times in 1,536 Posts
If Dan runs K SA and if I have figured his combo correctly at 299 HP the total weight including driver is 4055 lbs. I sure hope that 8.5 is as durable as a 12 bolt.
Old 04-22-2018, 09:56 PM   #4
Dan
Wrong again . I don't own a race car.
Old 04-23-2018, 10:33 AM   #5
Dan Fahey
Dan Fahey's Avatar
Having withdrawal envy. 😀
Old 04-25-2018, 10:09 AM   #6
Dan Fahey
Dan Fahey's Avatar
Been talking with Moser, Mark Williams and Strange
They do not make a C Clip Eliminator Kit and Axles for a 10 Bolt and with Disk Brakes..
They do not have a 12 bolt that bolts in
Looks like everything has to be fabricated to make it work.
Anyone have an idea how to get past this??
One other questions.
Can you use a G-Body Rear on a B-Body?
D
Old 04-25-2018, 12:28 PM   #7
Race Clean
Liked 129 Times in 53 Posts
My experience is that weight is what kills a rearend.
I moved to a lighter class and the rearend problems stopped,I probably have 100 more hp today than I had when I was breaking gears but no sign of cracking nowadays.
Most abused 12 bolt I've seen is from a 283 Impala (stick)
Race Clean is offline   Reply With Quote
Old 04-25-2018, 02:40 PM   #8
reera
Liked 31 Times in 6 Posts
69 Nova 350/255/280. 3250# in G/SA. 3390# in H/SA. 8.5" 10-bolt rear. Broke a couple teeth off 1 set of gears in 7 years. Strange c-clip eliminators, 33 spline axles, spool, richmond gears. Your results may vary.
Ryan Walther
Stock 315
reera is offline   Reply With Quote
