Old 04-22-2018, 09:09 PM   #31
MR DERBY CITY
Liked 7,938 Times in 1,519 Posts
Default Re: 12 Bolt vs 10 Bolt Rear
If Dan runs K SA and if I have figured his combo correctly at 299 HP the total weight including driver is 4055 lbs. I sure hope that 8.5 is as durable as a 12 bolt.
Old 04-22-2018, 09:56 PM   #32
Liked 5,121 Times in 1,952 Posts
You are right again....bluster blossom...
I am not under my car often...and that is a good thing!
and It helps to have a Forum to share experiences!
Mark you car is so slow.
It’s shadow waits for you at the end of the strip !
Dan
Wrong again . I don't own a race car.
Old 04-23-2018, 10:33 AM   #33
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Having withdrawal envy. 😀
Old 04-25-2018, 10:09 AM   #34
Dan Fahey
Dan Fahey's Avatar
Been talking with Moser, Mark Williams and Strange
They do not make a C Clip Eliminator Kit and Axles for a 10 Bolt and with Disk Brakes..
They do not have a 12 bolt that bolts in
Looks like everything has to be fabricated to make it work.
Anyone have an idea how to get past this??
One other questions.
Can you use a G-Body Rear on a B-Body?
D
Old 04-25-2018, 12:28 PM   #35
Race Clean
Liked 129 Times in 53 Posts
My experience is that weight is what kills a rearend.
I moved to a lighter class and the rearend problems stopped,I probably have 100 more hp today than I had when I was breaking gears but no sign of cracking nowadays.
Most abused 12 bolt I've seen is from a 283 Impala (stick)
Race Clean is offline   Reply With Quote
Old 04-25-2018, 02:40 PM   #36
reera
Liked 31 Times in 6 Posts
69 Nova 350/255/280. 3250# in G/SA. 3390# in H/SA. 8.5" 10-bolt rear. Broke a couple teeth off 1 set of gears in 7 years. Strange c-clip eliminators, 33 spline axles, spool, richmond gears. Your results may vary.
Ryan Walther
Stock 315
reera is offline   Reply With Quote
Old 04-25-2018, 03:48 PM   #37
Dan Fahey
Dan Fahey's Avatar
Ryan Walther
Stock 315
Oh have options.
But not one for my Axle using a Disk Brake.
Dan
Old 04-25-2018, 04:08 PM   #38
GUMP
Liked 2,354 Times in 554 Posts
You could always change the axle ends. It wouldn't hurt to weld the axle tubes to the center too.
Old 04-25-2018, 04:34 PM   #39
Dan Fahey
Dan Fahey's Avatar
Yeah..
Got a special case here.
Moser, Strange and MW do not specialize on B-Bodys.
Right now a new with good parts will cost $5000, Damn !
One asked if a G-Body 8.5 rear would fit.
Dan
Old 04-25-2018, 05:17 PM   #40
FED 387
Liked 333 Times in 180 Posts
look at the Police 91C rears they generally came with disc brakes---or as somebody said cut the ends off and put 12 bolt ends on it--google what you are trying to do others have put G body rears into a B body just have to rework the arms and move the brake hose/shock holes etc. to match what you have
