#31 |
Liked 8,004 Times in 1,526 Posts
If Dan runs K SA and if I have figured his combo correctly at 299 HP the total weight including driver is 4055 lbs. I sure hope that 8.5 is as durable as a 12 bolt.
#32 | |
Wrong again . I don't own a race car.
#33 |
Liked 184 Times in 113 Posts
#34 |
Been talking with Moser, Mark Williams and Strange
They do not make a C Clip Eliminator Kit and Axles for a 10 Bolt and with Disk Brakes.. They do not have a 12 bolt that bolts in Looks like everything has to be fabricated to make it work. Anyone have an idea how to get past this?? One other questions. Can you use a G-Body Rear on a B-Body? D Last edited by Dan Fahey; 04-25-2018 at 10:51 AM. |
#35 |
Liked 129 Times in 53 Posts
My experience is that weight is what kills a rearend.
I moved to a lighter class and the rearend problems stopped,I probably have 100 more hp today than I had when I was breaking gears but no sign of cracking nowadays. Most abused 12 bolt I've seen is from a 283 Impala (stick) Last edited by Race Clean; 04-25-2018 at 12:33 PM. |
#36 |
Liked 31 Times in 6 Posts
69 Nova 350/255/280. 3250# in G/SA. 3390# in H/SA. 8.5" 10-bolt rear. Broke a couple teeth off 1 set of gears in 7 years. Strange c-clip eliminators, 33 spline axles, spool, richmond gears. Your results may vary.
Ryan Walther Stock 315 |
#37 | |
But not one for my Axle using a Disk Brake. Dan |
#38 |
Liked 2,354 Times in 554 Posts
You could always change the axle ends. It wouldn't hurt to weld the axle tubes to the center too.
#39 | |
Yeah.. Got a special case here. Moser, Strange and MW do not specialize on B-Bodys. Right now a new with good parts will cost $5000, Damn ! One asked if a G-Body 8.5 rear would fit. Dan |
#40 |
Liked 333 Times in 180 Posts
look at the Police 91C rears they generally came with disc brakes---or as somebody said cut the ends off and put 12 bolt ends on it--google what you are trying to do others have put G body rears into a B body just have to rework the arms and move the brake hose/shock holes etc. to match what you have
