Liked 22 Times in 22 Posts
I may have a barn find. Says 302 on the air cleaner that was left on the engine after they robbed the carburetor. The intake is correct, and looks legit. Need to get inside of it, and take a peek. What’s one worth if I completely rebuild it to exact specs?
don,t have one |
Banned
Liked 179 Times in 89 Posts
If you can find the Z28 that it came out of, it'll be worth big bucks.
Other than that, if it's a 69, it's an 010 block with a 3" stroke crank and decent heads. JMO |
Liked 30 Times in 17 Posts
Bill Koustenis |
#4 | |
don,t have one |
Liked 772 Times in 192 Posts
Depends on which year. The casting numbers on the block, heads and intake will tell a lot. The '67 is the rarest; 602 were built. and complete engines were not offered through the parts network.
It came out of a 69. I’ll look up the numbers when I get it down here.
don,t have one |
Liked 10 Times in 6 Posts
Randy,before you do anything, call Jerry and talk with him regarding the stamp pad on the block.
He'll tell you what the code is for the 69 Z28 engine,and most importantly,what not to do to when cleaning it up to see it clearly. |
Will do. I promise. I’ve never actually been inside an original one.
don,t have one |
Liked 283 Times in 87 Posts
Randy… Does it have oil filler tube or not? Does it have bolt hole heads or not? Finned valve covers or stamped steel? MB
I know it has finned valve covers, I’ll look closer at the pictures tomorrow when he comes in. I do know it has straight plug heads. I spotted that.
don,t have one |
