Liked 920 Times in 259 Posts
It should be a simple calculation of piston area and master cylinder bore. But I've seen more than one car with Aerospace kits that should have worked, but didn't. Could not get a pedal, even with a big bore master, until a Lamb master was installed.
And I've seen guys get kits from Wilwood with calipers that had small bores for some reason (ordered wrong part# maybe) and the balance would be all out of whack. Strange has always been plug and play. |
Installed mine back in 2010, before I closed my shop. I don't know what another brand could do, that these do not. No pedal is not the brand. Wrong pedal ratio, or master cylinder bore. I was warned once about "smoking all 4 tires at the finish line." Didn't realize I locked them up. Wheels roll freely, good pedal, plenty of breaking power.
What else is there? Maybe they changed something.
Ed Wright 4156 SS/JA |
Liked 33 Times in 16 Posts
I'll have to concur with Ed...Aerospace being used on three different cars and no problems over the years. I would not expect any problems out of the other brands as well.
Rich Taylor I/SA - 321 |
I have wilwoods on 3 cars and never a issue. Aerospace on one car and always had to pump the pedal once at the end of a run to get anything.
2009 V/SA Record Holder |
Wrong bore size master cylinder, or need bled correctly. I have even seen calipers installed with the bleeder NOT at the very top. How do they bleed all the air out? LOL
Ed Wright 4156 SS/JA Last edited by Ed Wright; 05-06-2018 at 10:29 AM. |
Liked 28 Times in 15 Posts
when I built the Comanche nobody listed front disks for it.
I contacted aerospace and they said to send them a spindle and they could build the mounting plate (everything else is 5"X4 1/2 and available). ended up charging me $65 extra over the regular kits - and they have been on for 14 years. Very satisfied with the brakes and the customer service. Works for me. 1051 R/SA |
Liked 8,047 Times in 1,528 Posts
Everyone shoots for a nice FIRM pedal but I haven’t seen one post regarding DRAG......Absolutely NO drag with the Lamb setup....Aerospace not so much, but they do supply you with washers to shim their setup....
