Old 05-16-2018, 11:52 AM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Duster front suspension
Anyone willing to discuss the front end setup on an a-body mopar? Upper-lower control arms and strut rod for easy front end travel.
Mike
Old 05-16-2018, 02:49 PM   #2
GTX JOHN
Liked 2,487 Times in 698 Posts
Default Re: Duster front suspension
I use hard Duro bushings where available and make sure everything
moves with very little effort. If you can find the Direct Connection
Manual read it.......Old but good info!
John Irving
741 Stock
741 Super Stock
Old 05-16-2018, 09:46 PM   #3
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Prothane makes a good kit for the front on the Abody cars. I have used on a couple of cars.
Dyno is online now   Reply With Quote
Old 05-17-2018, 02:38 PM   #4
Coleydog
Thanks so far, anyone else?
Old 05-17-2018, 04:13 PM   #5
Hacksaw
Liked 311 Times in 175 Posts
Someone was making needle bearing replacements, ( Lamb ? ) , mostly for the Hemi guys. Also heard it was a little pricey.
Old 05-23-2018, 01:58 PM   #6
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Anyone know if there is a performance difference between prothane, needle bearings, and Delrin Bushings?
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 05-23-2018, 02:19 PM   #7
SSDiv6
Due to less compliance, Delrin and needle bearings will outperform Polyurethane based bushings. Delrin has a higher tensile strength and lower deflection when compared to Polyurethane
Old 05-28-2018, 02:03 PM   #8
Coleydog
I made some bronze bushings with grease fittings but I'm afraid they might bind with front end travel because of strut bar. Anyone have an opinion or facts if this will happen?
Reason I started this post
Mike
