Old 05-19-2018, 09:53 AM   #6
Eman
Liked 133 Times in 76 Posts
Default Re: Phoenix tires
I've replied on YB too. The frt. runners are tall compared to others and they work just fine. I've run them and have friends that run them. I've run the bias slicks for a few years in smaller sizes and have friends that run them in 14x32. They work well and last. They are the stickiest gooiest tires I've ever seen. You can load the car and let it sit for a week and when you unload if there is gravel the tire will look like a donut with sprinkles! After a pass your hand will stick to the tire. My biggest complaint running a small tire that is outside the 1/4 panel ate the lower rear is the rubber is brutal to get off of the car. You'll find little pieces of rubber everywhere and the smear and streak when you wash the car. It takes tar remover to get it off.
