Liked 53 Times in 38 Posts
Anyone willing to discuss the front end setup on an a-body mopar? Upper-lower control arms and strut rod for easy front end travel.
Mike |
Liked 2,493 Times in 700 Posts
I use hard Duro bushings where available and make sure everything
moves with very little effort. If you can find the Direct Connection Manual read it.......Old but good info!
Liked 695 Times in 206 Posts
Prothane makes a good kit for the front on the Abody cars. I have used on a couple of cars.
Thanks so far, anyone else?
Liked 314 Times in 177 Posts
Someone was making needle bearing replacements, ( Lamb ? ) , mostly for the Hemi guys. Also heard it was a little pricey.
Liked 5 Times in 2 Posts
Anyone know if there is a performance difference between prothane, needle bearings, and Delrin Bushings?
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
#7 | |
Due to less compliance, Delrin and needle bearings will outperform Polyurethane based bushings. Delrin has a higher tensile strength and lower deflection when compared to Polyurethane |
I made some bronze bushings with grease fittings but I'm afraid they might bind with front end travel because of strut bar. Anyone have an opinion or facts if this will happen?
Reason I started this post Mike |
