Marty, if your car is EFI, make a big change at like 6000 RPM, then see what RPM it shows up on your logger. I mostly look at high gear, since the A/F vs RPM error is going to be greater in lower gears due to the RPM increasing so much faster. And, I assume, if you leave off a 2 step, that your launch A/F looks much leaner due to the misfires caused by the 2step. Misfires put more oxygen in the exhaust, and our Wide Band O2 sensors calculate the air/fuel ratio by oxygen content.
I hope if you already knew all this, I didn't offend you. Maybe somebody did not know. Not trying to be a know-it-all.
Ed Wright 4156 SS/JA |
Liked 883 Times in 237 Posts
Just looked at my first run here at RT66 , my RacePak O2 is .021 behind RPM
Liked 232 Times in 39 Posts
Thanks Tom! Quite interesting what you are seeing. Bob Shaw and Bob Gullett are seeing .2 seconds and you are seeing ,02 seconds. Do you have any logic about why you are seeing so much less delay?
Marty Buth 3657 STK |
Marty , possibly because I'm reading 10" from the port as opposed to the collector.
I also have a brand new sensor installed for this race. I looked at a few runs from last week and they were closer to .014 seconds ,so age can defiantly be a factor. '
Thanks Tom!
So, Tom, your only looking at one cylinder?
You use a carburetor? I am not sure why you would choose that, over the round part of the collector, past the transition section.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 06-01-2018 at 11:12 AM. |
Liked 974 Times in 310 Posts
If to close to end of collector it will give you a false reading at speed..........ask me how I know.
#8 | |
