Old 05-31-2018, 11:21 AM   #1
M Brand 505B
Liked 31 Times in 10 Posts
Default 3rd Gen F Body Steering box
Looking to replace the steering box on our superstocker and checking to see which one is recommended. Thanks for the help.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 06-02-2018, 08:01 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 3rd Gen F Body Steering box
M, you have several choices.
* S-10 manual box [with the S-10 box in most cases it is a direct replacement. Input spline & pitman spline same as OE. It will have a four bolt top]
* manual GM box from 70's cars [this is also a direct fit in some cases. GM produced several spline counts so it takes some comparing to find the exact match. This is a three bolt top. This box is about one pound lighter than the S-10 box and overall slightly smaller.
* Vega box [this box is smaller and lighter than both the above, however, it requires a custom/special pitman arm. Ed Quay, Flaming River, and maybe others furnish the special arm.
Of the three, I would look for the 70's box.
Larry Woodfin 471W
Old 06-04-2018, 07:20 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
What about the ratio's?
Any difference in the ratios of the different boxes?
Quicker or Slower?
Adger Smith (Former SS)
Old 06-04-2018, 08:15 AM   #4
Dragsinger
Adger, I "think" all GM manual boxes will be about the same in ratio. [maybe an exception but it would be a rare option] The greater turn to turn ratio of manual boxes is an advantage, steering is not touchy]
The 60's and 70's three-bolt top gear is a good choice but it takes careful searching to find the correct spline count. They are out there, I have found and installed several.
An S-10 box is available reman from most parts stores. To my knowledge, there is only one part number. It's advantage, a direct bolt in replacement, remove power gear, install S-10 manual gear.
The quicker ratios come with PS boxes.
Larry Woodfin 471W
Old 06-04-2018, 10:31 AM   #5
Eman
Liked 133 Times in 76 Posts
I used the S-10 box, direct bolt in. I could have answered the ratio question last week as I just sold a Vega with a stock box.
Old 06-04-2018, 03:38 PM   #6
Adger Smith
When I was building my Roadster I found a rack & pinion setup that had a lot higher ratio so it eliminated over steering it. Just wondered about the available Gen 3 boxes.
Thanks.
Old 06-04-2018, 04:30 PM   #7
FED 387
Liked 333 Times in 180 Posts
I have a Chevy book (from GM ) 1984 that lists 2 Manual steering gear assemblies
7806396-------20:1 ratio---- 67-75 Camaro
7819935-------16:1 ratio---- Monza and Vega
FED 387
Old 06-05-2018, 11:58 PM   #8
Adger Smith
I did a little research on my Gen 3 tonight.
I found a 3 bolt top manual steering box
It has a number on the top frame rail side
that is 7808990
A quick search on the net seems to be the Vega box.
Old 06-06-2018, 11:02 AM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
that is 7808990
That's what my Buddies Gen 3 car has in it with an Ed Quay pitman arm. I have a Vega box in my gen 1 Camaro. It gives a bit more header clearance. They work fine and you can buy brand new ones from Jegs or Summit.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
