Old 06-01-2018, 12:11 PM   #1
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: 1972 buick 350 real seal
Originally Posted by Tom Broome View Post
I thought the 460 Ford worked in 455s, and the 350 took the same seal as the V6. Long ago I worked at Jim Ruggles' when we switched from rope to rubber. I thought the seal we used was from an AMC, but it's been a while.
I see that FelPro sells a neoprene seal for the V6s BS40613. Either way, make sure to polish the knurls down or it can chew the edge off of the neoprene seal (that much I do remember).
231 has 2.500 main journal diameter. 460 ford and 350 buick both have 3.000 main journal diameter. Fel pro bs40032 is the one to use.
