Old 06-04-2018, 11:24 PM   #1
jmoneyfoot
Liked 9 Times in 5 Posts
Default Approved fuel for low compression stocker
What would the best approved fuel be for a 9.5:1 dish piston 305 2bbl?
jmoneyfoot is offline   Reply With Quote
Old 06-04-2018, 11:47 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Approved fuel for low compression stocker
Sunoco 260GTX at 98 octane.
Do not any of the others are lower.
Old 06-05-2018, 12:57 AM   #3
Mepprecht
Mepprecht's Avatar
Liked 68 Times in 26 Posts
Most popular fuel is probably C11 in stock across the boards. That or c12.
Mike Epprecht
94 caprice P/SA - SS/PA 265
Mepprecht is offline   Reply With Quote
Old 06-05-2018, 01:44 AM   #4
GTX JOHN
Liked 2,487 Times in 698 Posts
X2 for C11 with that compression in our Stockers.
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 06-05-2018, 09:20 AM   #5
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Dan
The Sunoco 260gtx is an unleaded fuel, similar to VP C-10, easier on the A/F wideband sensors esp for the late model and dual duty street/strip use cars, although most guys on here will use the leaded fuels (C-11, C12) etc. to extend valve train life and achieve higher octane ratings. Another issue is availability, a racers preferred fuel may not be sold at certain tracks... Thanks to MG raceway for posting this chart..
http://www.maplegroveraceway.com/wp-...-reference.pdf
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 06-05-2018, 11:22 AM   #6
RKelliher
Liked 182 Times in 61 Posts
Run c-11 in my 81 305 dish motor . run about 3 hun.faster that c-12
RKelliher is offline   Reply With Quote
Old 06-05-2018, 11:33 AM   #7
Dan Fahey
Dan Fahey's Avatar
Originally Posted by Steve Stickel View Post
Dan
Yes 260GTX it is an unlead fuel and I like it !
I can find it and less expensive than C10.
RKelliher said that running C11 works better than C12.
How does is work that one Octane Fuel works better than another?
Dan
Old 06-05-2018, 12:35 PM   #8
terry1
Liked 24 Times in 13 Posts
Smile Re: Approved fuel for low compression stocker
Consistently, on a dyno, my engine makes 1% more HP with C11,
compared to VP110 or Sunoco Standard.
Terry K
terry1 is offline   Reply With Quote
Old 06-05-2018, 01:57 PM   #9
GTX JOHN
We also are faster with C11 than C12 in back to back testing
in our low compression Stockers!
John Irving
741 Stock
741 Super Stock
Old 06-05-2018, 03:16 PM   #10
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
C-11 was designed especially for low compression stock and super stock applications. Its not always readily available so you have to plan ahead and get that fuel ahead of time. C-12 is much more readily available and a bit cheaper. Not as fast in the low compression engines as the C-11 but runs very well. To get full advantage of the C-11 it takes a jet change as I remember. I run C-12 in my super stocker
Mike Pearson 2485 SS
