Old 06-05-2018, 03:18 PM   #11
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: Approved fuel for low compression stocker
C-11 makes the most power with my combo (dish 305). Tried them all!
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 06-05-2018, 03:31 PM   #12
Mepprecht
Mepprecht's Avatar
Liked 68 Times in 26 Posts
I’ve used mainly C12 (now using supreme Sunoco) and it always worked well in my p/sa 94 caprice 265 car... I never tried c11...
Mike Epprecht
94 caprice P/SA - SS/PA 265
Mepprecht is offline   Reply With Quote
Old 06-05-2018, 04:33 PM   #13
SDT1DYI
Liked 456 Times in 148 Posts
I have (4) 5 Gal cans of C 11 that were purchased in Boise. If there's a Div 6 or 7 stock racer needing C11 for Mission or Woodburn I could have the fuel there. All 20 gals 300.00 $
Steve, 6380 STK. 206 799 1544
SDT1DYI is offline   Reply With Quote
Old 06-05-2018, 05:32 PM   #14
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
If you have to mix fuels because of availability.
Are there any issues?
Can you run pump unleaded gas with the race fuel and be ok?
Dan
Old 06-05-2018, 05:55 PM   #15
Billy Nees
Liked 7,783 Times in 1,743 Posts
Dan
Dan, you MAY fail a fuel check if you have TRACES of unleaded fuel in your container.
So in answer to your question, no.
Billy Nees 1188 STK, SS
Old 06-05-2018, 08:06 PM   #16
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
I run Sunoco Standard- 110. Ran some Sunoco Supreme- 112 and slowed down a .1 in eight mile. Tried the new Sunoco Surge (105) at bowling green, seems like it picked me up but have not done back to back and weather was a factor. Dished piston 305 2 barrel.
Mike Moller
NHRA 203 Q-R-T/SA
Old 06-05-2018, 08:33 PM   #17
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
That happened to me at last years SportsNationals. I did not fail, but was noted it was flat. Tech offered to check my jug, but I remembered what had happened then over the winter when some non-ethanol was mistakenly poured in the cell.
Rich Taylor
I/SA - 321
Old 06-06-2018, 10:59 AM   #18
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Dan
Mixing fuels at an NHRA race is a No No. It will surely get you disqualified. Best is to always run the same fuel. I make sure I have enough fuel with me at all times. You cant always be sure to get what you need at the track. If you have to change for some reason make sure you drain the tank completely and then flush a bit of the new fuel through the system. This is the reason most run a small fuel cell in their cars. Makes it much easier to control the fuel issues.
Mike Pearson 2485 SS
Old 06-06-2018, 11:16 AM   #19
Dan Fahey
Dan Fahey's Avatar
YEAH I still have the stock tank.
Have an 8 gallon tank made and will install later.
Need to add a drain.
The warning about mixing fuels.
Does that include mixing Sonoco, VP dissimilar rating approved fuels?
Dan
Old 06-06-2018, 11:23 AM   #20
Hacksaw
Liked 311 Times in 175 Posts
Dan: Don't mix fuels, even if the colour is off they will fail it.
