Old 06-06-2018, 11:16 AM   #17
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Approved fuel for low compression stocker
Mixing fuels at an NHRA race is a No No. It will surely get you disqualified. Best is to always run the same fuel. I make sure I have enough fuel with me at all times. You cant always be sure to get what you need at the track. If you have to change for some reason make sure you drain the tank completely and then flush a bit of the new fuel through the system. This is the reason most run a small fuel cell in their cars. Makes it much easier to control the fuel issues.
YEAH I still have the stock tank.
Have an 8 gallon tank made and will install later.
Need to add a drain.
The warning about mixing fuels.
Does that include mixing Sonoco, VP dissimilar rating approved fuels?
Dan
