Old 06-15-2018, 07:51 AM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Re: Hoosier Slicks & front tires
Almost forgot... Bigley made these comments in the past, on this very website, about radial wobble. The topic is situations where it is probably unwise to use radials.
9. if your track's starting line is marginal at best, Again, radial slicks are not for you. Unlike bias slicks that will spin a couple of hundreds on a bad starting line, radials slicks spins TENTHS and don't recover.
11. radial slicks also have a history of doing something known as "radial wobble" where your car will rock side to side right after launching and it only gets worse as you continue down track to the point where you may have to lift. The reason for is touching down out of square meaning one tire hits the ground before the other after launching wheels up. Marginal track conditions will contribute as well and my experience is that it happens usually in the early and late season on cold tracks.
Old 06-15-2018, 11:34 AM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Bigley is also stating on this very website that if you're junk don't work on radials, you need help. specially someone that knows how to set up a chassis/suspension/shocks as is obvious you do as it's for sale
Again, I've had radial wobble ONCE almost 8 years ago and it was due to a cold track. Further, I never spin!!
Talk about what you know, not what you think you know!!
Old 06-15-2018, 11:45 AM   #3
nhramnl
You're hopeless. Bye, Ed!
Old 06-15-2018, 12:16 PM   #4
1320racer
1320racer's Avatar
You're clueless. Bye, Mike!
