Old 06-18-2018, 05:54 PM   #24
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
Some updates as Im getting close
Made alternator bracket out of scrap metal. 84 amp Alternator in car and works. Had large pulley on shelf
Using Ford relay just for junction to connect positive wires to and to use as a remote starter button. Found on shelf
Fuel system missing sample valve, but otherwise done
Front wheels mounted and balanced. Found new steel stems on shelf $20
New brake lines and some fittings $39
Steering arm $43
Double post style battery $45
I had all the braided lines new on shelf with fittings and old regulator from nitrous days. The rest of gauges were from another car that has a data logger and are all wired in. Playback tach and shift light wired.
Total $7933.98
