#471 |
Liked 251 Times in 125 Posts
#472 | |
You guys are gonna have a nice car. Can't hurt to take a breather. Making a car right isn't easy. Autumn, you are learning a LOT. Todd, this thread is showing what's involved in building a nice car. I would venture to guess that most casual onlookers will learn a lot from your well very documented experience. |
#473 | |
Todd Greene |
#474 |
Liked 320 Times in 102 Posts
Just my two cents......
You might consider upgrading with an Adapt-A-Cap from MSD. This type cap increases the spacing between the spark plugs contacts inside the cap and helps prevent misfires.. While you are at it drill a 7/16 hole in the cap midway between #1 spark plug and the coil terminal to correct the rotor phasing. Make sure you get the set with the adjustable rotor to correct phasing after you time it. Have fun...
#475 |
Liked 117 Times in 50 Posts
#476 | |
Todd Greene |
#477 |
It has strange fronts, I thought about putting a set of discs on the rear but just not sure if it's necessary.
Todd Greene |
#478 |
#479 |
Anyone have any real performance advantage data from the brake swap weight savings?
Todd Greene |
#480 |
Liked 7 Times in 5 Posts
we just recently swapped from drum to aerospace rear disk on our amx weight savings was 30lbs total about 20 of which was rotating i can't give any real performance data we changed engines too part of the winter upgrades. But that's roughly the weight savings.
