Very cool build.
Todd Greene |
Guest
Posts: n/a
I have a fresh lg journal 302 crank for sale if you need it. Just balance and go. PM me if interested
Liked 783 Times in 195 Posts
If you are building a race motor, you probably should consider different rods.
Liked 77 Times in 31 Posts
I would take Dwight advice, they make some nice aftermarket rods and N.H.R.A. approved list.it all depends how much H.P ,lot of variables
Liked 508 Times in 92 Posts
Why are you starting with a 2 bolt main block, 302 came with 4 bolt? The original blocks where 618 castings in '69. I'm not questioning your build, just pointing out different items, but in 1966 maybe they used 2 bolt blocks.
Also, if you are using an older block be sure to test the walls for pin holes. I personally got burned by the pin holes twice. Casey Miles 69 Z/28 Last edited by Casey Miles; 08-15-2018 at 07:58 PM. Reason: more info |
#6 | |
Liked 85 Times in 15 Posts
Pictures of rods. I will balance them next.
This is my first over haul, I hope to race, but I will keep the RPM around 7000 RPM, I will be running a light piston with a low drag ring pack. There was a guy that came around my Dads shop that bought a new 1967 Z/28, he said he buried the tach every day-anyone else ever heard this story?
Setting up for the line hone.
Nice progress.
Todd Greene |
