Personally I like the idea of keeping a small bore big stroke, if anything happened you still have room to bore.
middle of the pack is not a bad place to be. if you get going too fast it becomes hard to judge the very slow. one other issue with going big inch is everything else in your driveline has to be bulletproof
Liked 3,221 Times in 980 Posts
Assume you’ve got a fairly heavy car (my Super Street Avenger was right at minimum and only had 600 and could run 137); lightening the car yields the same results and helps with reliability and can possibly make it react faster, depending on your setup of course.
Liked 431 Times in 224 Posts
I wouldn't let the headers dictate your plans. I'm a big fan of small headers; they won't blow up the dyno sheet but always seem to ET well relative to the measured power.
The 632 in my dragster only has 2.25" headers and is an underachiever at 1020 HP, but all the other guys going 8.90 at 180+ seem to need 1200+ HP to do it and I'm in that club. I'd probably go with the longer stroke; more torque to get that car moving off the stop. And the smallish headers will help with velocity at lower RPM. Same with a smallish carb.
S/ST 51 S/C 53 |
Liked 4 Times in 3 Posts
the car is 3150 with me. it also sets a bit high and has the aerodynamics of a similar sized brick. i plan on lowering the front a bit this winter. wanted to let the new springs take a set before cutting them. I thought it would be faster than it is to but I'm sure it's the car and not the engine. It has a 488 rear right now and is going through the traps at about 7400 RPM. I've tried a couple of different converters. Right now I have a very consistent car in the 60 and im extremely happy with how the car drives. i can fab another set of headers if i need to just trying to keep it simple. i definitively agree with staying on the small side with pri tubes.
i talked to you this last weekend in great bend tony. i have the dark red 70 chevelle. thats an awesome nova you have. |
I knew you had some posts on the forum at the time we spoke! Great to actually meet you, and that Chevelle is extremely nice! I've never seen a car that said "Wagner's" on the door that wasn't mint.
S/ST 51 S/C 53 |
Liked 18 Times in 8 Posts
Go big or go home.
Banned
Liked 235 Times in 110 Posts
quote deleted .........
Liked 7 Times in 4 Posts
[QUOTE=gnicholson;574346]Right now I have a very consistent car in the 60 and im extremely happy with how the car drives. i can fab another set of headers if i need to just trying to keep it simple. i definitively agree with staying on the small side with pri tubes.
[QUOTE] If the car is very consistent why are we making changes? Is the engine worn out or do you just want to go faster? |
mostly i would like the car to be faster. i dont have to be on kill but 142 to 45 would work
