Old 11-04-2018, 06:33 PM   #741
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Glenn Briglio View Post
Have you seen any math for the auto combo?
I have in the past, and it's different in the aspect of the 2x torque multiplication of the converter. Basically the SLR # would be lower based on that.
Todd Greene
Old 11-04-2018, 06:42 PM   #742
Nmbr1GMfan
Saturday we spent the day cleaning up the shop, wow what a wreck! Today was actually 12 months to the day when the teardown began so I went in and just had a nice slow day. I had a plan to start dialing in the front wheel bearings but what I realized was I never checked the front brake drag after the system was finished. Needless to say, something isn't perfect as they do spin, just not real free. I'll get this lined out before the Nov. 25th test day.
Todd Greene
Old 11-05-2018, 09:50 AM   #743
Hacksaw
Liked 310 Times in 174 Posts
Several years ago ATI had a formula for the auto combo. Can't seem to find it anywhere.
Old 11-05-2018, 01:11 PM   #744
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
I remember seeing it.......it was based on engine stroke alone ....I think lol
Glenn Briglio is online now   Reply With Quote
Old 11-05-2018, 01:50 PM   #745
FED 387
Liked 333 Times in 180 Posts
there are various charts that have been around for quite a few years--- basically they all use rear gear ratio multiplied by first gear ratio---a guy named Dick Miller had a book out way back called""" hook & launch"""" or something like that where he used stroke and weight to calculate his numbers---others (Walcott) ATI etc. have charts that use tire diameters and other variables like HP to do their calculations---I believe that most of these are for AUTO trans cars not MANUAL trans cars---but even then those numbers might get you somewhat close as opposed to way out in left field trying to get a reasonably close ratio---bottom line is a 3000 lb car with a 5:00 gear and a 3:00 first gear making 400 HP and a 28-30 inch tire needs XXX ratio to be close ---you just have to figure that number out --- probably going to be somewhere about 10.00 -12.5 SLR probably----FED 387
Old 11-18-2018, 10:51 AM   #746
Nmbr1GMfan
Sorta been laying a bit low getting some little stuff done, still messing with brakes and stuff. Weather permitting we'll be at the track next weekend. Tires came in, I'll throw the rears on to test.
Todd Greene
Old 11-18-2018, 03:57 PM   #747
6130
Liked 117 Times in 50 Posts
Great news.
Hope you take lots of pics.
Old 11-18-2018, 04:09 PM   #748
David Lee
Liked 346 Times in 126 Posts
What size slicks did you settle on?
Old 11-18-2018, 06:33 PM   #749
Nmbr1GMfan
29.5/9 stiff
Todd Greene
Old 11-23-2018, 11:36 PM   #750
Nmbr1GMfan
Been workin' workin' workin'. seats been out, steering column out, pedal assembly out and all back in. New rear tires are on for now and had it aligned, wheelie bar is on. We'll go to the track Sunday and make some runs.
Todd Greene
