Old 11-26-2018, 09:55 AM   #1
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
"This is why we test". Things didn't go as expected but, well, they rarely do. Biggest issue was an oil leak that looks like maybe a rear main, not sure why, it didn't leak before. Car sounded really down on power and was running about 5mph slow, I believe we have a fuel issue. At 4 psi it would sound like it goes rich when the secondaries open, at 6 psi the car would be so rich it would shut off when the secondaries open, so obvious problems to sort out. Even though Autumn has been out of the car for a year she did a good job of driving as we tried a few new things. Engine will come out asap to check for the oil leak. I'll get some pictures up tonight and I'll see if a video will work someone else took and I'll go over mine tonight.
https://www.facebook.com/dan.bouldry...6411509757356/
Todd Greene
Old 11-26-2018, 01:14 PM   #2
Dave Gantz
Liked 251 Times in 125 Posts
Maybe the oil leak is the gauge connection at top/rear of the block?
Yep, why we test. You'll get it sorted quick enough.
Old 11-28-2018, 09:32 PM   #3
Nmbr1GMfan
Pretty sure to oil leak is at rear main and I have a theory. Worked a little bit this week on getting the engine prepped to come out, Autumn is coming down tomorrow and in a couple hours we'll have it ready to pull. Planning some parts strategy and I have a plan for a dyno session coming up. If possible I'm going to try to find a carb or two to try on the dyno so I have a comparison. Getting ready to do some parts ordering too. I will say that I think the tire swap was a huge improvement, even though we didn't hit it hard and it was down on power it did seem way better off the line. Here's a quick video from the test.
Todd Greene
Old 11-29-2018, 08:07 PM   #4
Nmbr1GMfan
We did manage to get a few little things done this afternoon. Organizing tools, getting a little closer to pulling it out, did a leak down and checked a few things just for verification before it comes out. Called Lakewood about a re-cert and a window... 8 weeks, that won't work so looking at options there.
Todd Greene
Old 11-29-2018, 09:21 PM   #5
FED 387
Liked 333 Times in 180 Posts
Todd--- safety suggestion. For your daughters safety I would suggest while working in the engine compartment that she put her in a ponytail or better yet a bun so doesn't get her beautiful hair either tangled up in something or burnt up. Great build up have been following it since day one. Keep up the good work it will eventually pay off big time . Regards Dick
Old 11-30-2018, 12:23 AM   #6
Nmbr1GMfan
Last week she was working under the dash, I went to put the clip back in the brake rod but couldn't find it, looked for about 30 minutes till we found it stuck in her hair.
Todd Greene
Old 12-02-2018, 12:28 PM   #7
Alan Nyhus
Liked 799 Times in 236 Posts
Glad to see it on the track, Todd.
When starting out with a QJet, I always advise people to use a known good carb. It can save hours of headaches and give you a benchmark for your own carb(s). -Al
"That'll never work....."
Old 12-02-2018, 03:08 PM   #8
6130
Liked 117 Times in 50 Posts
Lol.
My daughter has long hair too. When she was little, we used to find remnants of her last meal in it. Like behind her ears, not just on the tips.
Old 12-12-2018, 05:10 PM   #9
Nmbr1GMfan
Todd Greene
