Glenn, I think the springs were 350# open, I'll have to look at the notes tomorrow. I should stick a pic of the cam info on here and see if anyone knows who did it so I can call them to figure these springs out. I think the standard is about 200# and 400#. Fuel is VP C12.
Todd Greene |
Todd,
I used to use VP C-11 and had to do major repairs to heads and cylinder walls after the motor set for some time. I was told that the problem was from the VP fuel. Luckily I had changed over to Sunoco before NHRA had made their switch. Never had any troubles with my motors during the down time with Sunoco. VP is great fuel, I just had not been told to foam the motor after races. Good luck sir.
Keith A/S 2990/Terri A/SA 2991 "Imagine what you'd attempt, if you knew you could not fail!" |
Todd,
That would be just for the rust in your cylinder walls.
#4 | |
Todd Greene |
Liked 73 Times in 36 Posts
Todd,
Couldn't see oil filter adapter in the pics. Is the by pass plugged so everything has to go through the filter? IF not, I would highly suggest that for better filtration path. Looks like the dampers were being used as hole saws into whatever spacers were being used. Hardened locators are better solutions for sure. Might be worthwhile for you to measure the existing clearance on the gnawed up bearings so you can log what is too much for the weight lube you might be running. Are the piston skirts all chewed up as well? Wishing you the best of luck on the rebuild. Regards to you and Autumn, HB2 ![]() Dissident Hombre |
Liked 977 Times in 312 Posts
Yes rust in cylinders and on valves and seats is from fuel.
Liked 800 Times in 237 Posts
Todd, the VPC11 and C12 fuels will leave a little film of rust. Some light oil and a Scotch Brite pad and you'll be fine. I fog mine with Marvel Mystery Oil at the end of the season.
For valve springs, I'd highly recommend the PAC 1409X and matching their retainers. They were designed for this application. Controlling the lifter is critical with these stub nosed cams. https://www.racingsprings.com/index..../category/358/ A good high zinc oil is a must for long lobe life. Valvoline VR1 or Red Line are good oils https://www.redlineoil.com/20wt-race-oil-5w20 You'll be back in business in no time.
"That'll never work....." |
#8 | |
Todd Greene |
