Old 03-04-2019, 07:49 PM   #1
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Sunday. Sunday. Sunday... Well, Sunday brought much of the same, work work work. We got the intake on and realized the new valve covers don't fit with these rockers Got it off the stand, installed the cam plug and rear galley plugs, set it on the dyno cart and got everything hooked up.
Todd Greene
Old 03-04-2019, 07:52 PM   #2
Nmbr1GMfan
So Saturday night I had a conversation with my buddy Al who probably luckily steered me to swapping springs to break in the cam/lifters. Today (Monday) I sourced everything necessary to finish it up tomorrow, then we'll start thinking about a fire up.
Todd Greene
Old 03-04-2019, 08:10 PM   #3
FED 387
Liked 332 Times in 180 Posts
Todd if you really want to use those Chevrolet valve covers get some Ridgeway or Moroso valve cover spacers -- that should do the trick
Old 03-04-2019, 09:49 PM   #4
Nmbr1GMfan
Yes sir, got some on the way as we type.
Todd Greene
Old 03-05-2019, 11:21 AM   #5
Liked 5,118 Times in 1,950 Posts
I'm sure it's here somewhere, but why the new cam? What's different about it?
Old 03-05-2019, 02:05 PM   #6
Nmbr1GMfan
Mark, the cam is the same, I did send it out and had it profiled so I have a cam card. The lifters are being swapped out, that's why I'm breaking it in.
Todd Greene
Old 03-05-2019, 07:20 PM   #7
Nmbr1GMfan
Just a little info for everyone, seems a lot of people are running the PAC 1409X springs on their stockers. I had some issues finding an ID locator spring cup that would work because well, they didn't make one. Ended up having to make some for this particular head. When I questioned PAC, although they didn't recommend it, they said most were more than likely just throwing the 1409Xs in the head without a cup. Now fast forward to having my break in rockers not work, I needed a solution for a light spring for break-in. I ran across a direct drop in that works perfectly with the cup and the retainer from the 1409X... they're factory beehive Dodge Viper springs that will show about 85lbs at 1.800 (closed). Hope this helps someone in the future.
Todd Greene
Old 03-05-2019, 11:04 PM   #8
Gotcha .
You probably would have been alright without the extra steps. I won't even tell anyone what we did on a recent one. I don't want to give anyone any ideas. It broke in and runs fine though.
A good moly lube and some Lucas zinc additive helps a bunch, I think.
