Old 03-18-2019, 02:00 PM   #1
Keith 944
Keith 944's Avatar
Default Re: Towing with a Class B motorhome
Sounds like you'd have a similar experience as Keith with the exception of you'll go faster over the big hills!
Lol yes I would say so. It did great on hills, I would pass most of the diesels. Except for the vision problems, I forgot to add I only got 6 mpg towing or not! Not sure how that thing was geared. My old 38' diesel pusher towing gets 8-9
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 03-18-2019, 03:18 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,249 Times in 988 Posts
No doubt, and yes the ability to see down the road (often filled with idiots) is a big plus. I know my 450 Cummins was great going up and down the big hills out west (engine brakes are another big plus) and you feel like one of the big dogs until somebody with one of the 600 ISX Cummins goes blasting by. There's always somebody with a bigger stick and for the money it's hard to beat the E350/450 with the V10, especially ones with the six speed auto.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-18-2019, 04:48 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 977 Times in 312 Posts
I use a 2wd f150 now so I don't think there is a vision difference.
Old 03-18-2019, 05:18 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
My Class C is the shortest made. 25’ long overall. Wheelbase is the same as my long bed extra cab pickup. Distance from rear axle to hitch pivot is longer and it adds some tail wagging issues at times. E-450 chassis, V10- 5 speed auto overdrive. 4.56 gears. I reinforced my rear frame and hitch. Added airbags and good shocks up front. A weight distributing anti sway control hitch is a must. On good roads I can go 75. Pulling a 26’ trailer with my dragster and lots of spare stuff and equipment. V10 has lots of power and will pull any hill. Trans shifting is annoying. Trucks, and wind and rough roads and I slow down. Motor home stops better than my duramax pickup did with a Lance camper and trailer out back. V10 mileage is generally 7-8. I’ve had it going on 5 years. I’ve worked on class B’s doing generator work .They are Way to small to me....
Rich Biebel
S/C 1479
Stock 147R
