Liked 320 Times in 102 Posts
I'll just throw my 2 cents in.....
A few more points of internal engine oil leakage are the rod side clearance, if the rear main has had the split chamfered for more oiling to the thrust faces, cam bearing clearance, seal between the oil pump mounting surface and the cap, oil pump body to cover leakage and gear end play..... Do you monitor the oil pressure at the front of the block or the rear? A bad oil filter bypass valve doesn't vent to the pan it just bypasses the filter...
| Liked |
Rear. When I'm done I'll check it at both.
Todd Greene |
Pistons are off and rods are ready to be checked.
Todd Greene |
| Liked |
Liked 974 Times in 310 Posts
Are you doing this rebuild before those bottles were emptied..........j/k
| Liked |
After this deal, I'll be drinking for sure.
Todd Greene |
| Liked |
Decided to get the tires mounted earlier this week. Cut the shock mount and got a thin nut for clearance with the rim, hard to see but now we have clearance. Rears are on for good, front is on to check backspace and they're way better than the old ones (I'll add both pics to see the difference in backspace). Now we have to swap the new front studs in and bolt the fronts on for good.
![]() ![]() Before: too far out. ![]() After: nicely tucked. ![]() ![]() ![]() ![]()
Todd Greene |
| Liked |
Liked 251 Times in 125 Posts
How's the motor coming?
BTW, isn't it amazing that, with all the technology in this world, we have to buy tires that seem to have their lettering painted by a 2nd grade class? (Apologies to 2nd grade classes.) |
| Thread Tools | |
| Display Modes | |
